Convert "Walkie forklift" to 3-point attachment (Lifts 11 feet high)
   / Convert "Walkie forklift" to 3-point attachment (Lifts 11 feet high) #21
That's a lot of fluid.
I'm not sure what you have, but a B3200 only has a 3.8 gallon capacity as rswayn says. When you raise the mast, you are going to take out nearly half the hydraulic fluid in the tractor. That's not at all in the working range.
Sure, most of the time will be small lifts. But if there are times you will put the masts up and back up to drop something off or pick something up that's high, you want to make sure it's okay to operate the hydrostatic for a short period of time with only half the fluid in it.
I would check to see if the cylinder has a second port. Sometimes they just have a breather cap on the other port.
   / Convert "Walkie forklift" to 3-point attachment (Lifts 11 feet high) #22
Once you count hoses, it looks like you're getting near two gallons of fluid. If your system is only 3.8 gallons, its going to drain your tractor's hydraulics by more than half. Thinking about it, you may not have to consider the hoses. Its not going to drain anything past the compressed cylinder, so the volume in the hoses should never change. Anyhow, its still a considerable amount of fluid and that's not good. I don't know how your tractor is configured. Do you have separate transmission oil and hydraulic oil or is it all one system? If its all one system, you may want to reconsider using it, because you'd be draining your tranny by half each time you extended the mast all the way up.
Again, just something to look into. I've thought about getting a forklift like that for my Power Trac PT425, one with the wheels on the outriggers. But I have a 10 gallon hydraulic system. I hope you can make it work. Its a worth while project. :thumbsup:
   / Convert "Walkie forklift" to 3-point attachment (Lifts 11 feet high) #23
Why not buy a PTO pump, and build a hydraulic oil reservoir?
   / Convert "Walkie forklift" to 3-point attachment (Lifts 11 feet high) #24
That would be a good solution.... downsides are having to hook up a pump to the PTO and running hoses to the tractor each time you wanted to use it VS just hooking up two hoses. And it ads to the cost of the project significantly.
Plus side is you don't kill your tractor. :)
   / Convert "Walkie forklift" to 3-point attachment (Lifts 11 feet high) #25
We'll this is an insane idea but do able. Run a hydraulic motor off of your remotes to power a hydraulic pump to suck out of a reservoir to run lift.
   / Convert "Walkie forklift" to 3-point attachment (Lifts 11 feet high) #26
Probably because of the $700+ of added expense? You need the pump, hoses, reservoir, filter, and if you want any type of accurate control, its own control valve as well.
That may be the only solution though. :)
   / Convert "Walkie forklift" to 3-point attachment (Lifts 11 feet high) #27
However, being as he is starting with a walk behind forklift, he has a pump, hoses, reservoir, filter and a control valve (although it sounded like the valve had issues, perhaps a different section could be used?). He would just need a hydraulic motor to run the pump, or a new PTO pump and possibly a valve.
Aaron Z
   / Convert "Walkie forklift" to 3-point attachment (Lifts 11 feet high) #28
As far as hose volume goes I would neglect that in the calculation. Once you fill the hoses the first time the fluid will stay in there for all future uses.
   / Convert "Walkie forklift" to 3-point attachment (Lifts 11 feet high) #29
Aaron Z
Ah, I thought all that stuff was stripped, he only mentioned taking the electronics so I didn't know all that stuff existed. That's a better start then :)
   / Convert "Walkie forklift" to 3-point attachment (Lifts 11 feet high) #30
Perhaps he didn't, I just assumed he did from his "Been planning this for awhile but started on it yesterday, and stripped off all the electrics. Got some good stuff for the toybox" comment and his other thread where he was trying to fix it before deciding to bring it home.
Aaron Z
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
(2) METAL & WOOD STORAGE RACKS (A52708)
(2) METAL & WOOD...
NEW Wolverine Skid Steer Trencher (A59000)
NEW Wolverine Skid...
2015 Jeep Cherokee Latitude SUV (A55758)
2015 Jeep Cherokee...
Tank Only (A59076)
Tank Only (A59076)
2013 Cadillac SRX SUV (A56859)
2013 Cadillac SRX...
