ModMech
I use it, even mix brands, in any gas engine that gets used sparingly (pressure washer), but gets an oil change every year any way. If it's an odd weight I cannot use, it will accelerate the burn pile on a wet day
I only use one can of each type at a time. I go through 30W fairly often, so it never sits more than 3-6 mo unfinished. I do have a bottle of brake fluid that's been open for a couple of years that I occasionally need to top off the truck or car with. It's probably good for another few years before I reach the bottom.
Brake fluid is a different story. It is fairly hygroscopic (absorbs and retains water). Engine oil is not hygroscopic, and even if it were you'd boil off the excess moisture the first time you get the engine to operating temperature. Your brake system isn't like that, so you get decreased brake performance (mostly poor pedal feel) and risk corrosion in your brake system when you use wet fluid.
I keep the unused portion of the can from my most recent brake fluid flush on the shelf to top off in an emergency, but I'd never use old, opened, brake fluid in something I cared about.
use 5 gal plastic bucket 3/4 filled with sand / very fine gravel- pour in any left over oil until lightly wet - stick anything that needs light oil coating for protection/rust proofing into the sand. Nice for shovels, spades, hoes, mower blades etc. - garden tools - I leave them stuck in there until I need them. Come out clean and oily ...
