Adjusting a tiller
   / Adjusting a tiller
I had it in L1. By the time I throttled up I am moving pretty fast. With the skid shoes and the skirt on the side I don't see how it could go but so deep. It's not like a walk behind where you can bury it to the hub. No manual to look at and I've never seen one run.
   / Adjusting a tiller #12
If you were using the NH workmaster 55 the 1st gear speed is 1.76 mph, that is pretty fast for a small diameter tiller. Was this a 4 tine/rotor or 6 tine/rotor model?
   / Adjusting a tiller #13
I use a 6 ft king kutter and it will only go a few inches deep on untilled soil but will go deeper on additional passes. I can get it 8 to 10" deep in 3 passes. The skids need to sink in the soft tilled soil in order for it to till deeper.
It is a 6' TSC 4 tine. I looked at the specs and it said 40 hp max. I don't know if that matters other than tearing it up. I had already plowed this so it wasn't like its new ground.
   / Adjusting a tiller #15
I had a 4 tine tiller (Howard) and the max depth even with several passes was about 6 inches. The Deere 673 I have now has larger diameter rotors with 6 tines and approaches 8 inch depth in two passes. The travel speeds vary depending on the soil and moisture content but on my second pass I can usually run about 1.4 to 2.0 mph. If I pull it too fast it will climb up instead of tilling to full depth.
In your case with the smaller rotor diameter and the higher travel speed I suspect it is climbing instead of digging to full depth. To test this theory put the tractor in neutral and till a few feet while using the brakes to slow the tractor down. Creep along a few feet then see how deep it tills.
I took it back before it rained to get it off of my tractor. He said he would run it on his tractor this week. It was a cheap lesson learned before I went and bought one myself. I will probably just stick with my disc and put money in a rear tine to cultivate with.
   / Adjusting a tiller #17
Now you know why i don't like those poorly designed tillers... NOT all tillers are created equal!!
SR
SR
What makes a well designed tiller. Just in case I run across a deal. I would have been pissed if I had spent the $400 for this one and it didn't work.
   / Adjusting a tiller #19
New(er) Kuhn, Maschio or Howard, especially if it's not one of their bottom of the line models.
For me, my Howard replaced my moldboard plow and disc... I have customers that sell both of those tools right after they hired me to do some tillage for them with one of my Howards.
There IS a learning curve to using a tiller "properly", but once you do, it's a great tool!
SR
It looks like a 400B in 70" would be just rite for my tractor. What does one of those run in price. I noticed they had 8" listed as the depth for the really big ones. They didn't list a depth for the smaller ones.
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
UNUSED FUTURE FT-FM57 57" FLAIL MOWER (A51248)
UNUSED FUTURE...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A53472)
Kubota SVL65-2...
1272 (A50490)
1272 (A50490)
2022 JLG R3246 ELECTRIC SCISSOR LIFT (A51247)
2022 JLG R3246...
UNIVERSAL WOLVERINE PFF2-13-45W QUICK ATTACH MAST (A51248)
UNIVERSAL...
