Adjusting a tiller
   / Adjusting a tiller
I had it in L1. By the time I throttled up I am moving pretty fast. With the skid shoes and the skirt on the side I don't see how it could go but so deep. It's not like a walk behind where you can bury it to the hub. No manual to look at and I've never seen one run.
   / Adjusting a tiller #12
If you were using the NH workmaster 55 the 1st gear speed is 1.76 mph, that is pretty fast for a small diameter tiller. Was this a 4 tine/rotor or 6 tine/rotor model?
   / Adjusting a tiller #13
I use a 6 ft king kutter and it will only go a few inches deep on untilled soil but will go deeper on additional passes. I can get it 8 to 10" deep in 3 passes. The skids need to sink in the soft tilled soil in order for it to till deeper.
It is a 6' TSC 4 tine. I looked at the specs and it said 40 hp max. I don't know if that matters other than tearing it up. I had already plowed this so it wasn't like its new ground.
   / Adjusting a tiller #15
I had a 4 tine tiller (Howard) and the max depth even with several passes was about 6 inches. The Deere 673 I have now has larger diameter rotors with 6 tines and approaches 8 inch depth in two passes. The travel speeds vary depending on the soil and moisture content but on my second pass I can usually run about 1.4 to 2.0 mph. If I pull it too fast it will climb up instead of tilling to full depth.
In your case with the smaller rotor diameter and the higher travel speed I suspect it is climbing instead of digging to full depth. To test this theory put the tractor in neutral and till a few feet while using the brakes to slow the tractor down. Creep along a few feet then see how deep it tills.
I took it back before it rained to get it off of my tractor. He said he would run it on his tractor this week. It was a cheap lesson learned before I went and bought one myself. I will probably just stick with my disc and put money in a rear tine to cultivate with.
   / Adjusting a tiller #17
Now you know why i don't like those poorly designed tillers... NOT all tillers are created equal!!
SR
SR
What makes a well designed tiller. Just in case I run across a deal. I would have been pissed if I had spent the $400 for this one and it didn't work.
   / Adjusting a tiller #19
New(er) Kuhn, Maschio or Howard, especially if it's not one of their bottom of the line models.
For me, my Howard replaced my moldboard plow and disc... I have customers that sell both of those tools right after they hired me to do some tillage for them with one of my Howards.
There IS a learning curve to using a tiller "properly", but once you do, it's a great tool!
SR
It looks like a 400B in 70" would be just rite for my tractor. What does one of those run in price. I noticed they had 8" listed as the depth for the really big ones. They didn't list a depth for the smaller ones.
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
Как зайти с телефона на кракен. kra39ac.cc  | Kraken зайти на площадку? как пополнить кошелёк? Правила диспута
Как зайти с...
2014 DODGE CHARGER (A51406)
2014 DODGE CHARGER...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
