Buying Advice Used Kubota or New Kioti
/ Buying Advice Used Kubota or New Kioti #1
uponthriedge
Winston Salem, NC
Kioti DS4510
Just bought 30 acres of land about half cleared and the other half is woods. Looking for a tractor to do mowing, dirt moving, firewood hauling, log pulling, etc. This is my first tractor. Grew up operating Farmall and Case Tractors tractors as a kid. Paid my way through college running John Deere Backhoes and IH Loaders during my college years. Haven't been on any heavy equipment for 30+ years.
Have looked at Green, Red, Orange Brands. Green dealer is close 5 miles, but they just don't have a reasonable priced/featured model in the 40-42 hp range. Orange Dealers are both about 40 miles away. Red Mahindra Dealer is 20 miles away. Looked at them on the net but haven't gotten any formal quotes. Mahindra doesn't have a great reputation in our area. Large Kubota Orange Dealer has a used 2013 L4240 GST with 700 hours on it for 20,500. Positive would be no Tier IV emissions to deal with but no warranty and I like the solid build of the Kubota Grand Series. Small Friendly Kioti Dealer is about 40 miles away in opposite direction. DK4510 base model is 22,900 positive is it all shiny and new and comes with 2 year full warranty and 4 year power train. Considered the Kubota Grand L4060 with Hydro Transmission but having a hard time justifying the extra $6,700
Would appreciate any thoughts or recommendations.
Spreadsheet of specs
/ Buying Advice Used Kubota or New Kioti #2
It's all about service !!! Both good units.
/ Buying Advice Used Kubota or New Kioti #3
A Yanmar LX4500 would fit very nicely in your spreadsheet column, and you would have the tier 3 emissions and 5 year warranty you're looking for. One nice thing about the LX series is that they don't nickle and dime you for features like a quick attach bucket and telescoping links. Its all standard, and it has a throttle tied to the HST forward/back pedals you can toggle on/off for car-like driving.
Products - Yanmar Tractor
http://www.yanmartractor.com/content/resources/specsheets/LxHST_SpecSheet.pdf
Yanmar is able to produce tier3 engines models longer then other tractor makers due to EPA credits, but they won't last forever. At the very least this is one more CUT you can test drive before you buy. :)
/ Buying Advice Used Kubota or New Kioti #4
My only ill-informed thoughts would be that the non-turbo used Kubota has a larger, likely less-stressed engine producing its power. Do they all come with SSQA buckets? as I think you will find that an often used, and appreciated, feature. My three used Kubotas, all purchased as used machine, one with 500 hrs, one with 1000 hrs, and now one with 500 hrs have all been trouble free machines, without exception.
Have fun!
/ Buying Advice Used Kubota or New Kioti #5
I would go with the new Kioti, no doubt. From a specs standpoint it's as good, or better, in pretty much every category that really counts. It's a touch lighter, so you might want to get the rear tires loaded (avoid calcium chloride). The cool thing is that it has the rear 3pt control lever which really helps when hooking up attachments. Someone will surely come along shortly and claim that Kubota is far superior in every way (pretty sure only angel tears and $100 bills stick to Kubota paint), but Kioti builds a great tractor.
Thanks for the info. I really appreciate all the comments. I have been somewhat overwhelmed by all the choices and options. I don't mind paying a bit extra for a good value but just want to make sure the value is real vs marketing. Both tractors have the quick connect buckets. The Kioti has standard skid steer connection. Not sure about Kubota. The Kioti dealer said filled tires included in the price. I didn't ask if the used Kubota had filled tires. I heard that every Kubota goes out the door with filled tires so I assume they are filled. Not sure what they might be filled with. I am leaning towards the Kioti. I did like the rear 3pt control lever and of course the fact that they are assembled in my home state of NC. I had not heard of the Yanmar, just knew the name from the John Deere engines. Spec's look decent, I did find a dealer about 25 miles away. Emailed them for a price.
/ Buying Advice Used Kubota or New Kioti #7
I'd say look at both, test drive them, and then decide. Both compelling options to me.
/ Buying Advice Used Kubota or New Kioti #8
One thing you didn't mention is financing. It is often cheaper to spend a bit more and buy new, as you can get zero percent financing in many cases.
/ Buying Advice Used Kubota or New Kioti #9
We own four Kubotas, but of those mentioned my inclination would be to to go with the Kioti.
/ Buying Advice Used Kubota or New Kioti #10
My vote would be for the DK4510 but I would want it with the HYD shuttle which would probably cost a little more. Having a warranty with a 20,000 dollar purchase is big on my priority list as I have seen way too many disappointed folks who got the used machine and had problems. Might be worth a call top the dealer to see what the price difference would be for the DK4510 HS model rather than the base.
/ Buying Advice Used Kubota or New Kioti #11
I went with a New Kioti for the warranty and closeness of my dealer. You may want to give Robbie a call at Joe's Tractor if he were closer to me I would have probably bought a Tractor from him (just saying) Just my .02 worth
/ Buying Advice Used Kubota or New Kioti #12
Good call on the hydraulic shuttle...a world better than a standard manual transmission.
The Hydraulic shuttle is $1,000 more. The tractor I drove had it and I found that I ended up pushing in the clutch every time I went from forward to reverse. I guess just habit from riding a motorcycle with a clutch. Am I missing something. Seems like the only thing the HS does is eliminate the need to push in the clutch when shuttling between forward and reverse, that just doesn't seem to be worth $1,000 to eliminate need for clutch between forward and reverse. I can see advantage if I was a landscaper or doing lots of loader work, but I am guessing that 60-70% of tractor use will be mowing and 20% will be loader work. I guess I need to drive a tractor with manual shuttle shift.
Emailed two Yanmar dealers this morning but haven't heard from them. Prices all quoted are for cash, I like the cash discount. Don't like debt. Stopped by the Mahindra New Holland dealer just to see what they had to offer. New Holland workmaster 35 looked really cheap. They have tier 3 tractors but can't sell them due to EPA lawsuit. Dealer thought it would get resolved but I still don't think I would like the New Holland. Mahindra's are definitely beefy tractors but price was more expensive than comparable Kioti.
As for the 3 cylinder engine with turbo. I drive a 6 cylinder ecoboost Ford F150 which has been great and would not trade it for a V8. So if the 3 cylinder turbo on the Kioti performs like my Ford Ecoboost I will be happy.
Continue to lean toward Kioti despite the potential Tier IV issues. Kioti mentions 20% improved Fuel consumption with tier IV engines. Anyone have real world experience on that and how much that might save me per operating hour.
/ Buying Advice Used Kubota or New Kioti #14
I own a Kioti DK50SE-HST with cab and I like it a lot. But between the shuttle shift Kioti and the Glide-Shift L4240, I'd take the Kubota L4240.
I don't know how the specs compare, but the Grand L4240 is a really nice tractor, the Glide Shift transmission is much preferable (to me) than a standard shuttle shift, and Tier 3 is a big, big plus in my opinion. (Actually, it's Tier 4 Interim, but we usually incorrectly refer to that as Tier 3 - meaning no DPF, no regen, etc.)
/ Buying Advice Used Kubota or New Kioti #15
I think there are a couple of advantages to the hydraulic shuttle, but only you can decide if they apply to your situation or not.
One, many folks experience knee problems as they get older, and while that might not be an issue for you now, it could be down the road. More than a few folks here have said they went with a power shuttle/hydraulic shuttle, or HST for that very reason. Two, if you have any hills on your property, the hydraulic shuttle can be a bit safer because it's much harder to get caught in neutral, which can be bad on hills. Three, they really do make loader work, and even mowing faster/easier...some places it's easier to drive past, flip it into reverse and take care of quickly, but it's easy to get lazy and skip when you don't feel like pushing in the clutch....it happens. Lastly, from a resale standpoint I think the power/hydraulic shuttle would be a plus.
/ Buying Advice Used Kubota or New Kioti #16
What he said^. I think you can go back to the Kubota dealer and negotiate the price down. He should know better than to price a used machine at what a very nice Kioti goes for new.
/ Buying Advice Used Kubota or New Kioti #17
I guess for some folks it wouldn't matter much but for me and my uses the HYD shuttle is the way to go.
/ Buying Advice Used Kubota or New Kioti #18
Kioti. Tier 4 will not save you anything because it burns more fuel to produce less diesel particulate emissions when regenerating, etc. More parts, more expense, not yet out long enough to be proven reliable and cost effective overall. Just meets current laws from the EPA; last I heard they aren't tractor builders....
IF you can get Tier 3/interim Tier 4 machine, that would be best, BUT the Kiotis of that spec are hard to find new.
Thanks everyone for taking the time to comment. Much appreciated. Now I have to make the tough decision and decide on one or the other. At least I have narrowed it down to two from the 6 to 8 tha I started looking at. I was starting to get comfortable with the idea of a shiny new Kioti and that the Tier IV would not be an issue but need to go back to the Kubota dealer and do some more test driving and negotiating. As for the Kioti if I go with that I think you all have convinced me to go with the Hydro shuttle.
On the used Kubota. It was a trade in. Anyone have any idea what they may have gave the guy for trade in if based on what they are sale price offering, ie how much room does a dealer have to negotiate on a used tractor. When I first looked at the tractor they quoted a verbal 22,900. When I followed up and asked for written quote for the used tractor along with some prices on new Kubota's they dropped the price to 20,500.
/ Buying Advice Used Kubota or New Kioti #20
Being a Kioti guy, I'd go with the DK10, but only if it had the PST. The old DKSE was a great tractor, no reason why the new one won't be. If you're comparing the SS Kioti to the Kubota, go with the Kubota, the GST is great and the grand L is impressive. There may be a little room on the price for the Kubota, that sounds a little high, but there may be room on the Kioti price as well.
2016 FREIGHTLINER CASCADIA SLEEPER (A59905)
2016 FREIGHTLINER...
*Selling at Royal Auction Tampa, FL Location* (A59231)
*Selling at Royal...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2016 DRAGON SAND CONVEYOR (A58214)
2016 DRAGON SAND...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
