Building a fence - Backhoe or Auger?
   / Building a fence - Backhoe or Auger? #11
Auger definitely. I'd just pack good stainable fill back in around it and forget the concrete. You can hand tighten posts with a bar and they will be very solid
   / Building a fence - Backhoe or Auger? #12
I have the same problem as the OP, but I thought about going a different route.
I looked into renting a skidsteer with an auger. For about $300 dollars a day, you could poke a lot
of holes in an 8 hour period.
Rental company would deliver skidsteer and auger at 8am and pickup at 5pm. For a small nominal fee, of course.
:2cents:
   / Building a fence - Backhoe or Auger? #13
Please forgive my ignorance, but can you explain how to tighten the posts with a bar please?
   / Building a fence - Backhoe or Auger? #14
BTW, using 3/5 in. square in a 9 inch hole, 30" deep would take about 6.67 gallons of fill.
LOL, I was wondering the same thing. (and excuse my ignorance too)
And PMSMechanic, in reference to how much gravel, I was wondering in terms of how far from the post you should extend the gravel - ie if you do a 4"x4" post, it's good to use at least a 8" hole filled with gravel... I could care less how much it actually is volume wise.
   / Building a fence - Backhoe or Auger? #16
Around here, we call it packing the post. We use a 6 foot bar with a flat end to tamp the fill in the hole. I personally use a 6 foot iron pipe I got from HD and screwed end caps on it. Fill the hole with a few inches of the fill material and tamp it down till it sounds solid. You will hear the difference. Repeat until the hole is completely filled. Amazing how solid the post will be at that point. Also great for building up your arms!
   / Building a fence - Backhoe or Auger? #17
When setting fence posts generally the proper method is to drill the hole three times the size of the post you are setting. So for a 4x4 (3.5x3.5) would use a 10.5 inch hole. Unfortunately augers come in 9&12. It's rare to find a10.
In most cases adding gravel is not recommend as it will allow the water to continually surround post in wet conditions. I would not use a back hoe if u can avoid it.
   / Building a fence - Backhoe or Auger? #18
Hydraulic auger on your backhoe. All you have to do is cut your bucket curl line and add fittings and QDs. Run the auger with the bucket's curl and dump lever. 5-27-07 PHD Ops Ck.jpg
hugs, Brandi
   / Building a fence - Backhoe or Auger? #19
Analog I usually try to have about an inch of space or more around a pole. It's sometimes hard to get all the holes in a perfectly straight line so then the poles end up being off set to one side a little in the hole to keep everything looking straight. Personally I would probably use about a 9" auger on 4x4 posts. That gives enough room to move the post around in the hole to keep a straight fence. What I usually do is set my corner posts and then run a string line between to help keep things straight. For drilling I usually just mark where I want to dig the hole but for setting posts I space the string 1.5" off to the side and then measure to set the posts. That way if one post is a bit out it won't push on the string making all the rest of the posts a bit out. If you use crushed rock you don't have to pack the posts at all. Just wiggle them once the holes are full of rock and you can feel them tighten up. If you don't like where you've set your post they are easy to change. Just lift it out and clean out the hole and reset your post.
I don't like using concrete around post because quite frankly it's a lot of work. If you make a mistake it's even more work. I'm not so sure that concrete keeps water away from the post. Every time it rains the water runs down the post and in between the cement and the post. Any cemented posts I've seen rot off in the first four inches of cement. I'm just putting posts in the way the power company's do. I really like the self tightening action of crushed rock.
   / Building a fence - Backhoe or Auger? #20
"BTW, I was thinking an auger on the 3 point, not a handheld one. I already tried a handheld and it was a b*tch. ""
Every time I see one of those hand held units, I can't help but imagine the three stooges using one of those those and what a calamity it would turn into if my two boys and I were to try it! :eek:
When I was in high school we built a fence with a hand held auger. Me and my uncle had the job of digging holes, I don't know how many holes we had done but it was getting to the end of the day and we were getting tired when we hit our first rock that was big enough to stop the bit. In a flash both of us were on our but on the opposite side of the hole that we had started on, the auger was just sitting in the hole slowly spinning the motor at an idle...
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
iDrive TDS-2010H...
500BBL WHEELED...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2004 JOHN DEERE 310G BACKHOE (A60429)
2004 JOHN DEERE...
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
