New Guy with a Ford 1700
   / New Guy with a Ford 1700
Well, the weather finally got good enough to crawl around on the ground (I am not as young as I used to be). So, it begins!
I used my backhoe to hold the loader arms up while I backed out of them, then shifted them out of the way.
I spent the rest of the afternoon taking off the loader mount. There are a LOT of cracks that need repair. I knew there would be. Although I operate this little tractor as carefully as I can, I do a lot of work with it (much more then this motorized wheelbarrow was designed to do). I have a 580K Case, but my yard is very sloped, which makes it very hard use the wider bucket (and almost impossible to snow plow).
Today I will remove all the steering, fuel, and electrical connections (along with the 4WD driveshaft). I have a small skid I will build a platform on to support the front end, and use a pallet jack to separate the two halves. Luckily, I found a spot that is relatively level, so I don't have to do the work in front of my house!
The pins in the 770 loader are badly worn. Does anyone have a source for replacement loader pins? They are all 1" OD. Thanks!
Got it apart!
Not really that hard to do, just a LOT of things to disconnect! The real trick is going to be to line everything up when it goes back together. I took it apart by myself, but I may need a hand getting everything to line up when I slide back together.
Gee, I wonder why the clutch stopped working?
   / New Guy with a Ford 1700 #13
I think you may have found the problem.
Well, the good news is, the pressure plate going left fabric on the clutch. So, my flywheel is not really worn badly. The clutch didn't chatter at all, so I am thinking I am just going to leave the flywheel alone. However, does anyone have a good method for removing the pilot bearing from the end of the crankshaft?
   / New Guy with a Ford 1700 #15
They make a tool to do that. But who owns one of those right??
I used a foot long piece of rod, welded a washer on one end that was small enough to go inside the hole. Clamped a pair of vise grips on the other end. Slipped the washer in behind the bearing, then tapped on the vise grips with a small hammer and pulled mine out.
Sounds like a plan, thanks! I also discovered the trick of packing the blind hole thru the bearing with grease, bread, or wet paper, then driving in a rod that provides a tight fit to the ID of the bearing. The resulting pressure pushes the bearing out (thanks YouTube). I will try this first.:)
   / New Guy with a Ford 1700 #17
Mine came out very easily. I was lucky.
Anxious to see results of your reassembly. Hope it all goes well. As my Dad would say, "What this calls for is a high level of maturity". In other words, "Patience is a virtue". :)
Thanks for your good wishes! Having a background in repairing construction equipment, and making my living as an industrial mechanic, has given me a lot of experience (if not wisdom). Slow and steady always pays off!
I would love to pull the flywheel, and replace the rear main seal (as soon as I score a 2 1/2" socket to get the nut off). Are there any issues with prying out the seal around the end of the camshaft I should know about? I plan on prying it out with a screwdriver (haven't removed the flywheel, so I am guessing what it looks like in there), and then turning a piece of pvc pipe to act as a tool to drive the new seal on.
Thanks!
   / New Guy with a Ford 1700 #19
The main seal was very easy to remove and install for me. Shouldn't be a big deal. And I'd certainly want to replace it while there. As I mentioned in my thread, replace every seal in there while you are there.
   / New Guy with a Ford 1700 #20
I found 1" pins at Tractor Supply Co for my 770 loader.
Best of luck with your clutch job.
I'll just pass on my experience with the brakes... several years ago I bought a used (1980, I think) 1700 and it's brakes were toast. I took off the covers and just a pile of powder fell out, lol. Pricing a new set of brake shoes just left me angry, so I decided to re-shoe them myself. Bought a few feet of 1/4" or 3/16" thick (can't exactly remember which) "brake/clutch lining" and some flat-head brass rivets from McMaster-Carr. The lining was the perfect width and thickness, so I just had to drill & countersink for the rivets, and rasped down the leading & trailing edges of the lining. They have worked great and saved a ton of money!
2008 Club Car Electric Carryall 2 Utility Cart (A56859)
2008 Club Car...
2007 Chrysler Aspen SUV (A56859)
2007 Chrysler...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
Misc Pallet of Nails and Building Supplies (A57454)
Misc Pallet of...
2018 John Deere Z997R (A53317)
2018 John Deere...
2004 Chevrolet C5500 Flatbed Service Truck with crane, VIN # 1GBE5C1214F513547 (A57453)
2004 Chevrolet...
