Oil of Kubota engine B2320
   / Oil of Kubota engine B2320 #1
Conchal Sao Paulo
Kubota B2320
hello, I make the first oil change my tractor Kubota B2320, in Brazil not sell original oil Kubota, I'm with much doubt, someone can help me in relation of the oils below:
Shell Rimula R4 API CI-4, GC-4, 4-CF, CF.
Shell Rimula R3 API CH-4, GC-4, 4-CF.
Tection Castrol 15W40 API CI-4 / SJ.
Castrol 15W40 Crb - Synthetic API CF-4.
Castrol Magnatec Professional Semi Synthetic Diesel 15W40 - API CF-4.
thank very much.
   / Oil of Kubota engine B2320 #2
I use Shell Rotella T6 in my BX. Exceeds OEM specs and works well.
   / Oil of Kubota engine B2320 #4
make sure it says "for Diesel use" when you get the Synthetic oil.
   / Oil of Kubota engine B2320 #5
Rotella T6 is a heavy duty diesel oil. Works well in all temperature ranges.
   / Oil of Kubota engine B2320 #6
Although any of the oils mentioned would be suitable for your engine,I would be inclined to choose a CI-4 rating since it's the latest specification available to you.
It sounds like you still have diesel fuel with a higher sulpher content than we have here in the US.
Good Luck!
ok, here in Brazil I found the Shell Rimula R6 100% synthetic API: CI-4, CH-4, CG-4, CF-4, I will start using, in Brazil there is not Shell rotella t6.
Temperature here is 86 ° F.
Thank you very much.
Good Luck!
here in Brazil I found the Shell Rimula R6 100% synthetic API: CI-4, CH-4, CG-4, CF-4, I can use this ?.
I'm using diesel S10.
   / Oil of Kubota engine B2320 #10
here in Brazil I found the Shell Rimula R6 100% synthetic API: CI-4, CH-4, CG-4, CF-4, I can use this ?. I'm using diesel S10. Thank you very much.
Yes, this oil is a very good choice for your tractor. In Brazil you do not yet have engines requiring CJ-4 oil. CI-4 oil is the best choice for you.
Quick Attach Pallet Forks (A47384)
Quick Attach...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
John Deere TX 4x2 Utility Gator (A49346)
John Deere TX 4x2...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2013 FORD F-550 SUPER DUTY XL BUCKET TRUCK (A51243)
2013 FORD F-550...
