Oil of Kubota engine B2320
   / Oil of Kubota engine B2320 #1
Conchal Sao Paulo
Kubota B2320
hello, I make the first oil change my tractor Kubota B2320, in Brazil not sell original oil Kubota, I'm with much doubt, someone can help me in relation of the oils below:
Shell Rimula R4 API CI-4, GC-4, 4-CF, CF.
Shell Rimula R3 API CH-4, GC-4, 4-CF.
Tection Castrol 15W40 API CI-4 / SJ.
Castrol 15W40 Crb - Synthetic API CF-4.
Castrol Magnatec Professional Semi Synthetic Diesel 15W40 - API CF-4.
thank very much.
   / Oil of Kubota engine B2320 #2
I use Shell Rotella T6 in my BX. Exceeds OEM specs and works well.
   / Oil of Kubota engine B2320 #4
make sure it says "for Diesel use" when you get the Synthetic oil.
   / Oil of Kubota engine B2320 #5
Rotella T6 is a heavy duty diesel oil. Works well in all temperature ranges.
   / Oil of Kubota engine B2320 #6
Although any of the oils mentioned would be suitable for your engine,I would be inclined to choose a CI-4 rating since it's the latest specification available to you.
It sounds like you still have diesel fuel with a higher sulpher content than we have here in the US.
Good Luck!
ok, here in Brazil I found the Shell Rimula R6 100% synthetic API: CI-4, CH-4, CG-4, CF-4, I will start using, in Brazil there is not Shell rotella t6.
Temperature here is 86 ° F.
Thank you very much.
Good Luck!
here in Brazil I found the Shell Rimula R6 100% synthetic API: CI-4, CH-4, CG-4, CF-4, I can use this ?.
I'm using diesel S10.
   / Oil of Kubota engine B2320 #10
here in Brazil I found the Shell Rimula R6 100% synthetic API: CI-4, CH-4, CG-4, CF-4, I can use this ?. I'm using diesel S10. Thank you very much.
Yes, this oil is a very good choice for your tractor. In Brazil you do not yet have engines requiring CJ-4 oil. CI-4 oil is the best choice for you.
2020 VOLVO VNL64T740 TANDEM AXLE MID ROOF (A51222)
2020 VOLVO...
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
EVERYTHING SOLD AS-IS WHERE IS!! (A50774)
EVERYTHING SOLD...
John Deere 270 Compact Wheel Loader Skid Steer (A50322)
John Deere 270...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
