Culvert Question
   / Culvert Question #1
justinramani
Gold Member
North Carolina
Mahindra 4035
Hello Everyone!
The wife and I are getting ready to have a culvert installed across a creek on our property. We originally were looking at double wall HDPE plastic, but a guy we know out here happens to have two sections of 36" x 8' concrete culverts that he is willing to sell to us for about $140. The culverts look to be in great condition. The two together will give us about a 16' crossing.
The HDPE (plastic) pipe would have been one piece and 20' long, but would be significantly more expensive. We have a guy that can load and transport the concrete culverts to our property for a very reasonable price.
What do y'all think? Go with the concrete, or opt for the HDPE?
Thanks in advance
Justin
Fayetteville, NC
   / Culvert Question #3
Only 16' of concrete culverts isnt gonna leave you a 16' opening. At least not unless you pour concrete around the ends or come up with some other kind of retaining wall. With ~2' or so of dirt on top of the culverts, you are gonna loose about 3' each side from the bottom of the culvert to the flat of the crossing. So your actual crossing will me more like 10' wide. If just for tractors, ATV's or foot traffic that is probably fine. But for full sized vehicles, that wont seem very wide of a crossing.
And are you sure 36" is large enough? Any pics of the area?
   / Culvert Question
LD1,
You think we will really lose out on 3' each side? I figured we may lose some space, but I didn't think we would sacrifice 6' across a 16' length. I don't have any pics of the area right now, but I can probably get some later today or tomorrow. I see a lot of driveway culverts that cover almost 100% of the length of the pipe. Those culverts don't look like they lose out on any width. I am far from an expert on these things - so your advice is greatly appreciated.
   / Culvert Question #5
I share LD1's concerns about the width. But then, we haven't saw the site nor heard how deep you are burying the culvert??
My next concern would be setting the concrete culvert. What's your plan for that?? I have no idea what 8' of 36" concrete culvert would weigh?? Lastly, you'll have to create a very solid platform to lay it on to keep it joined and filling the hole will be critical.
The plastic is wayyyyyyyyy easier to deal with. And the cost will seem irrelevant next year.
Only down side to the plastic is burning. Again, not sure of the surroundings but if it's grassland that you frequently burn you'll hafta babysit around the ends while burning so you don't get it on fire. Otherwise it's extremely durable and you'll never have to mess with it again.
   / Culvert Question #6
LD1,
At a glance you should have a pretty good idea how much fill you'll have over the culvert?? So what's your guess??
   / Culvert Question
We are thinking about 1 foot of fill on top of the culvert..... I will snap a picture and post it up in a few minutes so that you can better see the area.
- Justin
   / Culvert Question #8
3' loss os over 5' height, assuming its 2' burried. Thats slightly steeper than about a 60 degree angle. It could easily be more than that with erosion. Depends on what the fill is.
I agree, go plastic. ITs longer to start with. And you can handle it easy. With the cost of moving and setting, plastic will probably be cheaper in the long run.
   / Culvert Question #9
+1 to the shoulder comments.
The price for the concrete culvert is great, but it may just be a little short depending on your needs.
A 20' culvert sounds great, then by the time you get your surface on and shoulders cut in, you can't get 2 rigs driving side-by-side any more. Starting at 16', you're already in the hole.
~Moses
   / Culvert Question #10
- Justin
That helps. But understand LD1's point. You can't get the dirt fill to stand vertically. So with that 1' of fill over the top of a 3' culvert you now have 4' of fill to hold in place. Being a total optimist you are going to lose 3' on each end. Now you have a 10' drive.
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2001 Freightliner FL80 E-One Pumper Fire Truck (A52377)
2001 Freightliner...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
