30hp Chinese Bulldozer Parts
   / 30hp Chinese Bulldozer Parts #51
So what does all that mean? It means you can probably upgrade to seven discs if you want to. Two extra discs and one extra plate. Compare stack height.
   / 30hp Chinese Bulldozer Parts #53
Ok thats weird so it is correct to have a metal plate last on the stack and then the cover plate. I would think that metal spacer and cover will slip. Being its metal to metal.
   / 30hp Chinese Bulldozer Parts #54
The cover plate #8 and the end plate #7 turn at the same time and direction, so no friction. Note the splines and bolts.
   / 30hp Chinese Bulldozer Parts #55
Ok thanks for all the info. I really appreciate it. Should have all the seals on friday then I can put it all back together.
   / 30hp Chinese Bulldozer Parts #56
Ok have a new problem. Does anyone have the hydraulic hose diagram location for the shuttle shift lever on the left side while sitting on the dozer. I used toap to label the hoses and oil soaked the tape and they fell off. Any help deeply appreciated. Thanks
   / 30hp Chinese Bulldozer Parts #57
Does your machine have an accumulator? I think I may have asked you this before. Best way to label hoses is to take pictures with the labels on them.
   / 30hp Chinese Bulldozer Parts #58
Ya I used a metal stamp on the right side controls. Not sure but there are 4 lines that connect to the forward and reverse control. 2 lines on the actuator lever cylinder and 2 lines come from the right side controls. Wish I did take pics for backup but didnt.
   / 30hp Chinese Bulldozer Parts #59
Ya I used a metal stamp on the right side controls. Not sure but there are 4 lines that connect to the forward and reverse control. 2 lines on the actuator lever cylinder and 2 lines come from the right side controls. Wish I did take pics for backup but didn't.
Here ya go. Hope it helps.
   / 30hp Chinese Bulldozer Parts #60
............. and 2 lines come from the right side controls.
Wait, what? Don't you have two hydraulic pumps on the engine? Are you getting the pressure source from the tractor hydraulics?
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2008 STOUGHTON TRAILER STOUGHTON TRAILER (A55745)
2008 STOUGHTON...
BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD-78HF...
2015 Chevrolet Silverado 1500 Pickup Truck (A53422)
2015 Chevrolet...
2019 Chevrolet Silverado 2500 4x4 Warner Service Truck (A55852)
2019 Chevrolet...
2015 Ford Transit 150 Cargo Van (A53422)
2015 Ford Transit...
