30hp Chinese Bulldozer Parts
   / 30hp Chinese Bulldozer Parts #51
So what does all that mean? It means you can probably upgrade to seven discs if you want to. Two extra discs and one extra plate. Compare stack height.
   / 30hp Chinese Bulldozer Parts #53
Ok thats weird so it is correct to have a metal plate last on the stack and then the cover plate. I would think that metal spacer and cover will slip. Being its metal to metal.
   / 30hp Chinese Bulldozer Parts #54
The cover plate #8 and the end plate #7 turn at the same time and direction, so no friction. Note the splines and bolts.
   / 30hp Chinese Bulldozer Parts #55
Ok thanks for all the info. I really appreciate it. Should have all the seals on friday then I can put it all back together.
   / 30hp Chinese Bulldozer Parts #56
Ok have a new problem. Does anyone have the hydraulic hose diagram location for the shuttle shift lever on the left side while sitting on the dozer. I used toap to label the hoses and oil soaked the tape and they fell off. Any help deeply appreciated. Thanks
   / 30hp Chinese Bulldozer Parts #57
Does your machine have an accumulator? I think I may have asked you this before. Best way to label hoses is to take pictures with the labels on them.
   / 30hp Chinese Bulldozer Parts #58
Ya I used a metal stamp on the right side controls. Not sure but there are 4 lines that connect to the forward and reverse control. 2 lines on the actuator lever cylinder and 2 lines come from the right side controls. Wish I did take pics for backup but didnt.
   / 30hp Chinese Bulldozer Parts #59
Ya I used a metal stamp on the right side controls. Not sure but there are 4 lines that connect to the forward and reverse control. 2 lines on the actuator lever cylinder and 2 lines come from the right side controls. Wish I did take pics for backup but didn't.
Here ya go. Hope it helps.
   / 30hp Chinese Bulldozer Parts #60
............. and 2 lines come from the right side controls.
Wait, what? Don't you have two hydraulic pumps on the engine? Are you getting the pressure source from the tractor hydraulics?
2004 Volvo XC90 VAN (A55853)
2004 Volvo XC90...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2015 Peterbilt 320...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
2024 Case IH Patriot 4450 Sprayer (A53485)
2024 Case IH...
2019 Chevrolet Express 2500 Cargo Van (A53422)
2019 Chevrolet...
2023 John Deere 333G Track Loader (A53485)
2023 John Deere...
