Solar Fence Trouble Shooting
   / Solar Fence Trouble Shooting #42
I have 1.6 amps showing on the grounding wire, but no direction. I am thinking the meter may not be designed to show current on the ground wire?
Something has to complete the circuit (get shocked). Any volunteers?
   / Solar Fence Trouble Shooting #43
anytime I see a voltage measurement on a ground I figure I haven't got enough grounds or they are working poorly. It may be that the soil is dry and contact is poor or simply not enough rods. Sometimes a bucket of water with a small leak will help if placed beside ground post.
   / Solar Fence Trouble Shooting #44
I had the meter on amperage, I did not measure the voltage. The odd thing was it did not show a direction.
   / Solar Fence Trouble Shooting #45
I have noticed that when current flow is small, the direction arrow is often missing.
Also, interestingly, I have seen the current arrow reverse direction between pulses. I have learned that this means that there is a medium sized leak in a Y arm behind me, toward the charger. It's as if the electricity goes down both legs of the Y with a pulse then hits the end of the fence and bounces back to the medium leak leg before the next pulse. Rubber electrons, I guess. Electricity is strange, sometimes.
   / Solar Fence Trouble Shooting #46
I expect to see some odd current flows when the leak are intermittent, wind blowing etc. All in, this is turning out to be a big help on the fences.
500LB Livestock Galvanized Creep Feeder (A55218)
500LB Livestock...
2002 VOLVO L150E WHEEL LOADER (A51246)
2002 VOLVO L150E...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
