Solar Fence Trouble Shooting
   / Solar Fence Trouble Shooting #42
I have 1.6 amps showing on the grounding wire, but no direction. I am thinking the meter may not be designed to show current on the ground wire?
Something has to complete the circuit (get shocked). Any volunteers?
   / Solar Fence Trouble Shooting #43
anytime I see a voltage measurement on a ground I figure I haven't got enough grounds or they are working poorly. It may be that the soil is dry and contact is poor or simply not enough rods. Sometimes a bucket of water with a small leak will help if placed beside ground post.
   / Solar Fence Trouble Shooting #44
I had the meter on amperage, I did not measure the voltage. The odd thing was it did not show a direction.
   / Solar Fence Trouble Shooting #45
I have noticed that when current flow is small, the direction arrow is often missing.
Also, interestingly, I have seen the current arrow reverse direction between pulses. I have learned that this means that there is a medium sized leak in a Y arm behind me, toward the charger. It's as if the electricity goes down both legs of the Y with a pulse then hits the end of the fence and bounces back to the medium leak leg before the next pulse. Rubber electrons, I guess. Electricity is strange, sometimes.
   / Solar Fence Trouble Shooting #46
I expect to see some odd current flows when the leak are intermittent, wind blowing etc. All in, this is turning out to be a big help on the fences.
2005 FONTAINE 48 FOOT FLATBED (A53843)
2005 FONTAINE 48...
Case 1150G Crawler Tractor Dozer (A53421)
Case 1150G Crawler...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
2014 Dodge Charger Sedan (A52377)
2014 Dodge Charger...
Harrell 3605 (A50123)
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
