Oil differentiation between diesel and auto applications
   / Oil differentiation between diesel and auto applications #41
   / Oil differentiation between diesel and auto applications #42
hmm.. i see oil # 12 is the cummins/valvoline full syn blue 5w-40 diesel oil i use in my pickups... not bad numbers...
   / Oil differentiation between diesel and auto applications #43
   / Oil differentiation between diesel and auto applications #44
... more on PC-11 (BOHICA comes to mind):
North American specification update - March 2015
"Concern over technology changes and back serviceability for PC-11
One of the drivers for oils with 800 ppm phosphorus is to give those marketers that require it, the ability to add an API S claim for universal oil for gasoline engines.
However, at the January NCDT meeting, Ford presented data showing that a premium PC-11 capable oil, designed at 800 ppm phosphorus, did not perform well in a smaller 6.7 litre diesel engine calling for an API CJ-4 engine oil. Ford felt that the reduction in ZDDP from ~1200 ppm phosphorus to 800 ppm was too large a change. In their view significantly more field testing would be required for them to be assured that these oils will not cause issues in older and even some current production engines."
Keep in mind the EPA would be all too happy if you toast your old diesel engine becasue then you'd have to buy a new one at the current emission level. Educate yourself and hide your wallet!
   / Oil differentiation between diesel and auto applications #45
Create a Crisis, to Drive an Agenda..... ?
Naw, they'd never do that ! ;)
Rgds, D.
   / Oil differentiation between diesel and auto applications #46
Do you really believe the U.S. EPA is driving the emissions changes? Europe is putting pressure on the U.S. To follow their upcoming change to Stage 5. Japan is already using engines with tighter restrictions than the U.S. In small diesels. Even China would like to get there but their infrastructure is too antiquated to handle the better engines so instead the people wear masks to protect their lungs on the worst days. America is actually rather loose on their requirements compared to most of the first world countries. So oil spec - can somebody please post the EPA regulation that specifies what an engine oil used in a Tier 4 final engine must use? EPA śpecs the final emissions and does limit sulfur in diesel, but CJ-4 is a spec developed by the engine and oil companies as a requirement in meeting the emissions spec. You guys hit me at another bad time because this evening I learned of another schoolmate diagnosed with terminal lung cancer, a non-smoker who spent his career in our mines. Diesel soot? Dust particles? Nothing is for certain except that our miners suffer lung cancer at a rate 5 times higher than the standard population. Everybody has to go sometime but coughing blood out of your lungs gasping your last breaths?
   / Oil differentiation between diesel and auto applications #47
Sorry to hear about your friend. I pray for his healing, comfort for the family and wisdom for the doctors.
To answer your question, yes. If you read all those links, you'll see the changes are mandated by the Govt.
   / Oil differentiation between diesel and auto applications #48
Don't worry Tier 5 is on it's way for the U.S. Because Tier 4 was not successful in stopping Diesel engine sales. Tier 6 is a possibility after Tier 5.
   / Oil differentiation between diesel and auto applications #49
The story goes that if you will purchase lube oil in a 55 gallon drum. Shell will sell the good stuff, the old spec CI-4plus Rotella, not the wimpy CJ-4 Rotella in today's stores .
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
1983 Case 580D (A47477)
1983 Case 580D...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
