TRIVA FUN
/ TRIVA FUN #861
I haven't read the whole thread so don't know if its been asked.
What is the only rock that floats?
Don't cheat and google. :)
/ TRIVA FUN #862
I believe some pumice is light enough.
Bruce
/ TRIVA FUN #864
What was the Japanese torpedo called that gave the U.S. Navy so much trouble in WWII?
Germany developed some AT guns in WWII that had designations such as 50/37 mm. What did this mean?
The Japanese torpedo was called the Long Lance (easy question for WWII submarine buff)
I think the example you gave would be this.. the bore diameter would be the 37 MilliMeter. The length of the barrel would be 50x37 MM or 1850 Millimeters. That might not be right, but that is what I think.:)
/ TRIVA FUN #865
:) I'll guess at the sabotg diameter as 50mm and the "bullet" at 37mm. For the life of me I can't think of the proper term for the weapon that is fired using a sabot.
Harry K
Harry K
/ TRIVA FUN #866
Harry K
Harry K
here is what I found on the net.
The length of the barrel (especially for larger guns) is often quoted in calibers. The effective length of the barrel (from breech to muzzle) is divided by the barrel diameter to give a dimensionless quantity. As an example, the main guns of the Iowa-class battleships can be referred to as 16"/50 caliber. They are 16 inches in diameter and the barrel is 800 inches long (16 × 50 = 800). This is also sometimes indicated using the prefix /L; so for example, the most common gun for the Panzer V tank is described as a "75 mm /L70," meaning a barrel with an internal bore of 75 mm, and 5,250 mm long (17 ft 2.69 in).
The bore to barrel length ratio is called caliber in naval gunnery, but is called length in army artillery. Before World War II, the US Navy used 5"/51 caliber (5"/L51) as surface-to-surface guns and 5"/25 caliber (5"/L25) as surface to air guns. By the end of World War II, the dual purpose 5"/38 caliber (5"/L38) was standard naval armament against surface and air targets. All three had a bore diameter of 5 inches (not 5.51 or 5.25 or 5.38 as often misread).
/ TRIVA FUN #867
Correct on the Romans paying troops and others in salt. It was so useful a commodity in the days before refrigeration.(Think salt pork, corned beef, hams etc.) that every household needed as much as a hundred pounds a year and you could trade any excess for other goods and services. The crude oil of the day.
/ TRIVA FUN #868
The German Pak 41 was an anti tank weapon that used a squeeze bore to attain muzzle velocities over 4000 fps. The bore started at 75mm at the breech and tapered to 55mm at the muzzle. An earlier version was to 50/37mm. Bet the barrels didn't last long!
Interesting article on Wiki about it. The barrel came in thee pieces.
/ TRIVA FUN #869
Which artist was the first to record the song "Blueberry Hill"?
/ TRIVA FUN
There are 14,000 know uses of salt.
At one time it was more valuable than gold.
What is a common metal today at 1 time was worth more than gold.
Not talking about iron or steel, which in the long run are more useful than gold.
/ TRIVA FUN #874
Aluminum. At one time was more expensive than Gold
/ TRIVA FUN
What or whose court room trial was the first to be broad cast on Radio???
/ TRIVA FUN
One US president was shot in the chest.
With a bullet in his chest he went on to give a 30 minuet speech.
Who would that be????
/ TRIVA FUN #879
Well, I should have know that one, but I didn't so I looked it up.
/ TRIVA FUN
A common mineral compound that you may have in your home and / or shop has many many uses.
What is this mineral compound?????
No fair googling:D
2014 Ford Explorer SUV (A59231)
2014 Ford Explorer...
(164) PALLET OF SAFETY CONES (A60432)
(164) PALLET OF...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
40' CONTAINER (A60432)
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
