Why does flux core wire weld thicker metal than MIG?
   / Why does flux core wire weld thicker metal than MIG? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Why does the same machine setup with flux core wire weld thicker metal than the same machine set up as MIG? My Lincoln SP170T owner's manual gives a chart that shows flux wire welding a noticeably thicker steel than just MIG wire with shielding gas. I don't understand this.
   / Why does flux core wire weld thicker metal than MIG? #2
I don't really know the technical answer:eek:. I would assume because flux core has a hotter puddle. Now dual shield with gas coverage, has the best of both worlds. Slag and gas coverage.
I have welded up to 4-inch thick material with 1/16-inch Mig wire. Worked in a fab shop in the 1970s, we had to test every 3-months with Mig on 1-inch thick V-butt plates.
Flux core with gas. Very interesting.
   / Why does flux core wire weld thicker metal than MIG? #4
You'll see dual shield used more often than Mig in structural fab shops. And boy is it fast! :cool2:
   / Why does flux core wire weld thicker metal than MIG? #5
I think it has to do with the vapor that the flux core wire makes.
Kind of like using helium, instead of argon, will produced a hotter weld (same current) with TIG welding.
What does the weld look like? Quality?
   / Why does flux core wire weld thicker metal than MIG? #7
Here are some dual shield welds I made a few years ago.
First pictures shows the slag coverage.
Third picture is a vertical up hill weld.
wow is that impressive.
   / Why does flux core wire weld thicker metal than MIG? #9
I didn't do any of the welding, I was the project superintendent. This was for an outfall just down river of the Bonneville dam, on the Columbia river. We drove 10-feet diameter pipe, drilled them out, and welded another section to the driven section, and drove it. The outboard piles went over 200-feet into the rock. All welded with dual shield, 100% x-ray.
   / Why does flux core wire weld thicker metal than MIG? #10
Would love to be able to have a close up look at that kind of operation. how long does it take to drive a pile that deep, and how far does it go with each blow of the pile driver.
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
STEAM CLEANER (A55745)
LINCOLN WELDER (A55745)
LINCOLN WELDER...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
2020 HINO 268 26FT NON CDL BOX TRUCK (A54313)
2020 HINO 268 26FT...
2001 Dodge Ram 3500 4X4 Flatbed Truck, VIN # 1B7MF33651J565664 (A54865)
2001 Dodge Ram...
