Why does flux core wire weld thicker metal than MIG?
   / Why does flux core wire weld thicker metal than MIG? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Why does the same machine setup with flux core wire weld thicker metal than the same machine set up as MIG? My Lincoln SP170T owner's manual gives a chart that shows flux wire welding a noticeably thicker steel than just MIG wire with shielding gas. I don't understand this.
   / Why does flux core wire weld thicker metal than MIG? #2
I don't really know the technical answer:eek:. I would assume because flux core has a hotter puddle. Now dual shield with gas coverage, has the best of both worlds. Slag and gas coverage.
I have welded up to 4-inch thick material with 1/16-inch Mig wire. Worked in a fab shop in the 1970s, we had to test every 3-months with Mig on 1-inch thick V-butt plates.
Flux core with gas. Very interesting.
   / Why does flux core wire weld thicker metal than MIG? #4
You'll see dual shield used more often than Mig in structural fab shops. And boy is it fast! :cool2:
   / Why does flux core wire weld thicker metal than MIG? #5
I think it has to do with the vapor that the flux core wire makes.
Kind of like using helium, instead of argon, will produced a hotter weld (same current) with TIG welding.
What does the weld look like? Quality?
   / Why does flux core wire weld thicker metal than MIG? #7
Here are some dual shield welds I made a few years ago.
First pictures shows the slag coverage.
Third picture is a vertical up hill weld.
wow is that impressive.
   / Why does flux core wire weld thicker metal than MIG? #9
I didn't do any of the welding, I was the project superintendent. This was for an outfall just down river of the Bonneville dam, on the Columbia river. We drove 10-feet diameter pipe, drilled them out, and welded another section to the driven section, and drove it. The outboard piles went over 200-feet into the rock. All welded with dual shield, 100% x-ray.
   / Why does flux core wire weld thicker metal than MIG? #10
Would love to be able to have a close up look at that kind of operation. how long does it take to drive a pile that deep, and how far does it go with each blow of the pile driver.
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
40' CONTAINER (A51244)
2018 CUMMINS CM20-1 PORTABLE SKID GENERATOR (A55745)
2018 CUMMINS...
2008 Komatsu PC228 (A47477)
2008 Komatsu PC228...
2012 Ford F-550 Crew Cab SWAT Transport Truck (A55852)
2012 Ford F-550...
