Oil Change Mess
/ Oil Change Mess #1
ronchp
Limestone, TN
Mahindra 3616
My Mahindra 3616 has a plate across the frame directly below the engine oil drain plugs. Plate sure is nice for protection, but makes a mess trying to drain the oil--looks like an oil sprinkler. I have been looking at a couple of the replacement plugs with flow control valves. I am comparing those at www.nospillsystems.com and Fumoto Valve | Qwik Valve™. Both appear quality equipment. I am leaning toward the nospillsystems design so far for my tractor because it appears a little more secure from the drain getting opened accidentally from brush under the tractor because it has a cap over the valve. If anyone has an experience with either one, please share your info and thoughts. Thanks.
/ Oil Change Mess #2
I've used the fumoto valve before and it works great. Then I would take it a step further and mount a 3/4 or 1" hydraulic line a couple feet long. Then cap the other end of the hydralic line with a plug. Then when I want to change the oil, I just unscrew the plug and open the valve. I'll tuck the hose into the frame using a pipe clamp for mounting to the wall to keep the hose from getting snagged when the tractor is in use
/ Oil Change Mess #3
I don't have any experience with either one and was only familiar with the Fumoto design. I have wanted to install a quick valve on New Holland tractors with Fiat/Iveco engines to allow easier access and avoid the mess on draining oil on tractors with SuperSteer as well. Personally, I am going to get the No Spill system for the same reason you sited; avoidance of it possibly opening in brushy conditions. Also, the No Spill has a similar low profile to the original oil plug.
/ Oil Change Mess #5
Or bend a little piece of sheet metal in a vee that you can wedge up on top of the offending cross bar while it is draining. That's what I do when draining the outboard rear axle housings on my Kubota. Just the cheap in me I guess.
- Jay
/ Oil Change Mess #6
How about a "form-a-funnel".. I think i first seen one a few years ago.
Is there no place you can park to let the frame drip-dry?
/ Oil Change Mess #7
Drill a large hole in the skid plate, like 2" or so right under the drain plug.
/ Oil Change Mess
Thanks for the feedback. After reading the reviews, now I think I may go with the hand pump oil extractor. Looks pretty useful for small engines also, so I could probably get more use out of it.
/ Oil Change Mess #9
Often wondered if an extractor gets as much oil out as opening the plug. I am kind of **** about getting out as much of the old oil. After all, isn't that the point to this fun excercise?
/ Oil Change Mess
Good point. Another plus I noted on the no spill systems design is it includes magnets to hold metal debris.
/ Oil Change Mess #12
I use the extractors regularly mostly on marine engines and they don't work very well with cold oil, but 45 min for 3 quarts dose not sound right at all
/ Oil Change Mess #13
- Jay
Even a good grade of cardboard works the same way.. It only has to last one oil change.:)
/ Oil Change Mess #14
Or some of your wife's aluminum foil can make a handy custom funnel / oil flow diverter. And the bonus is you can aggravate your wife by stealing her aluminum foil and not putting it back where you found it.
/ Oil Change Mess #15
I believe that would work!:)
/ Oil Change Mess #16
I know its not completely the same, but changing oil filter on my Harley does the same thing.. makes a big mess. I use the side from a half gallon milk bottle.. makes a great diverter and lasts quite a few changes. Experiment with how you cut it to fit till you find the right size shape.
4x9 Homemade Utility Trailer (A62613)
4x9 Homemade...
2017 Ford F-150 Ext. Cab Pickup Truck (A61572)
2017 Ford F-150...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2008 Chevy Trail Blazer (A62679)
2008 Chevy Trail...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
2011 Chevrolet Silverado 1500 Work Truck (A62613)
2011 Chevrolet...
