Oil Change Mess
/ Oil Change Mess #1
ronchp
Limestone, TN
Mahindra 3616
My Mahindra 3616 has a plate across the frame directly below the engine oil drain plugs. Plate sure is nice for protection, but makes a mess trying to drain the oil--looks like an oil sprinkler. I have been looking at a couple of the replacement plugs with flow control valves. I am comparing those at www.nospillsystems.com and Fumoto Valve | Qwik Valve™. Both appear quality equipment. I am leaning toward the nospillsystems design so far for my tractor because it appears a little more secure from the drain getting opened accidentally from brush under the tractor because it has a cap over the valve. If anyone has an experience with either one, please share your info and thoughts. Thanks.
/ Oil Change Mess #2
I've used the fumoto valve before and it works great. Then I would take it a step further and mount a 3/4 or 1" hydraulic line a couple feet long. Then cap the other end of the hydralic line with a plug. Then when I want to change the oil, I just unscrew the plug and open the valve. I'll tuck the hose into the frame using a pipe clamp for mounting to the wall to keep the hose from getting snagged when the tractor is in use
/ Oil Change Mess #3
I don't have any experience with either one and was only familiar with the Fumoto design. I have wanted to install a quick valve on New Holland tractors with Fiat/Iveco engines to allow easier access and avoid the mess on draining oil on tractors with SuperSteer as well. Personally, I am going to get the No Spill system for the same reason you sited; avoidance of it possibly opening in brushy conditions. Also, the No Spill has a similar low profile to the original oil plug.
/ Oil Change Mess #5
Or bend a little piece of sheet metal in a vee that you can wedge up on top of the offending cross bar while it is draining. That's what I do when draining the outboard rear axle housings on my Kubota. Just the cheap in me I guess.
- Jay
/ Oil Change Mess #6
How about a "form-a-funnel".. I think i first seen one a few years ago.
Is there no place you can park to let the frame drip-dry?
/ Oil Change Mess #7
Drill a large hole in the skid plate, like 2" or so right under the drain plug.
/ Oil Change Mess
Thanks for the feedback. After reading the reviews, now I think I may go with the hand pump oil extractor. Looks pretty useful for small engines also, so I could probably get more use out of it.
/ Oil Change Mess #9
Often wondered if an extractor gets as much oil out as opening the plug. I am kind of **** about getting out as much of the old oil. After all, isn't that the point to this fun excercise?
/ Oil Change Mess
Good point. Another plus I noted on the no spill systems design is it includes magnets to hold metal debris.
/ Oil Change Mess #12
I use the extractors regularly mostly on marine engines and they don't work very well with cold oil, but 45 min for 3 quarts dose not sound right at all
/ Oil Change Mess #13
- Jay
Even a good grade of cardboard works the same way.. It only has to last one oil change.:)
/ Oil Change Mess #14
Or some of your wife's aluminum foil can make a handy custom funnel / oil flow diverter. And the bonus is you can aggravate your wife by stealing her aluminum foil and not putting it back where you found it.
/ Oil Change Mess #15
I believe that would work!:)
/ Oil Change Mess #16
I know its not completely the same, but changing oil filter on my Harley does the same thing.. makes a big mess. I use the side from a half gallon milk bottle.. makes a great diverter and lasts quite a few changes. Experiment with how you cut it to fit till you find the right size shape.
Linx UT357714T 14ft Trailer (A65640)
Linx UT357714T...
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
2020 JOHN DEERE 333G SKID STEER (A65053)
2020 JOHN DEERE...
2022 EZ-GO ELITE...
John Deere 24in Backhoe Bucket (A65640)
John Deere 24in...
