dmccarty
Super Star Member
David
2) the speed of the kinetic machine while amazing is also dangerous IMHO. Imagine a long day first felling a tree, then limbing and cutting it up. Fatigue sets in. But wait, you need to split the wood before it's dark! You rush and get a little careless, you forget to move your hand from the splitter path. In a second, your hand or fingers are crushed or mangled. Enough said.
With the hydraulic splitter, you have 15 sec or so to move your hand out of the way, or you can stop the split by simply releasing the lever of the control valve.
I have only noticed one other post bringing up the safety issue with the faster splitters. I would not own a kinetic for just this reason. I have pinched my fingers with the hydraulic splitter. I felt the pinch and moved my hand or stopped the splitter. If I had done this with a kinetic splitter I would have a nickname like Nine Finger Dan or One Thumb Dan. :shocked: I often hold the wood to be split so that it is split just so which is not really dangerous with a "slow" splitter.
Later,
Dan
