Making pivot pins - what kind of steel to use?
   / Making pivot pins - what kind of steel to use? #1
jim_wilson
Northeast MA
Kubota B3200 w/ BH77 & 12", 18" & 24" buckets, Kubota B50 SSQA w/ 54" & 60" buckets, LandPride FDR1660, Artillian Fork frame, Extreme 3pt rake, Concrete Mixer, MyTractorTools grapple adapter
I'd like to make some lubricatable pivot pins for the thumb on my Kubota BH77 backhoe. The factory supplied pivot pins do not have grease fittings and after the hoe sat for a number of months - I ran into a problem because one of the pins was so dry the thumb was hanging up.
I've also got an idea on how to make a "better" pin - which distributes the grease more evenly - but I'm not sure exactly what type of steel would be best suited to making a replacement pin.
Anybody have any insight into this?
Thanks!
   / Making pivot pins - what kind of steel to use? #2
If it were mine, I would make it out of mild steel with the idea that it is easier to replace a worn pin than worn bushings. And any steel pin would be incredibly strong in a clevis arrangement if there isn't much clearance between the two sets of "shoulders".
Another issue might be whether to have it plated or not.
   / Making pivot pins - what kind of steel to use? #3
I would use Gr5 if you can get it conveniently. The unthreaded shank of a big bolt is a source at Tractor Supply. Avoid drilling and grooving pins to prevent cracking. Better to grease thru the casing/bushing to spare the stress risers from modifying the pin.
   / Making pivot pins - what kind of steel to use? #4
Tractor supply has bins of pins.
   / Making pivot pins - what kind of steel to use? #5
I would make them out of 4140 or 4340 prehard.
   / Making pivot pins - what kind of steel to use? #6
Cold roll steel should work just fine for your application. Its ease of machining, and tensile strength make this steel a good candidate for making pins. It is also easy to get,and affordable.
Bolts are cheap and a good alternative to "real" pins. Or just get ready made ones with grease nipple...
   / Making pivot pins - what kind of steel to use? #7
These would be my first and second choice also. You can get the material from McMaster Carr. A third choice is 8620. If you have a place nearby that you could have the 4140 or 8620 heat treated, you will not be sorry.
   / Making pivot pins - what kind of steel to use? #8
just drill the pin you have for nipple?
   / Making pivot pins - what kind of steel to use? #9
pin.JPGAgree with MOwens. 4340. Here is a sample pin we use for industrial applications. About as severe as you can get with abuse. They hold up well.
   / Making pivot pins - what kind of steel to use? #10
If the joint does not have replaceable bushings I use phosphor bronze. It is stronger than mild steel, although I think strength is not an issue because a pin sized for the bearing load is much larger than needed for the shear load.
If the joint suffers from lack of lubrication the bronze will wear before the steel. Bronze pins have been on front end loaders for over a dozen years with no problem, though I do keep them well greased.
Zero Turn Mower (A59231)
Zero Turn Mower...
Deere 310L (A53317)
Deere 310L (A53317)
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
