Best way to engage rotary cutter
   / Best way to engage rotary cutter #11
I think a lot of us have engaged a brush hog at high RPM and scared the bajeebers out of ourselves.... :laughing:
Common... admit it folks... you know you did it... :confused3:
:D
   / Best way to engage rotary cutter #12
:D
Nope. That's hard to do on an older machine like mine with a live PTO- But I will admit to killing a rabbit and 2 kittens by not following the advice I offered in post #9. Also, I had to lift my Hico into a pickup (with help from the young bride) 32 years ago before I could get it home and use it, so we got the clanking noise introduced to us prior to use.
   / Best way to engage rotary cutter #13
:D
Actually the secret is to let out the clutch nice and easy. It never fails. I'm still waiting for the bajeebers to leave.;)
Thank you all...all good stuff. My independent pto has an on/off and a link selection which automatically disengages the pto when I raise the 3pt. I scared the crap out of myself the 1st time I engaged it even below 540...I wasn't expecting the shake, rattle and roll. Engaging at idle and ramping it up to 540 obviously works the best, I just wanted to make sure I was doing anything wrong.
   / Best way to engage rotary cutter #16
I ain't got no clutch. :confused3:
Then you ain't got no tractor!:hissyfit: Just kidding. I've looked through your blog and was amazed at what you do with that little guy!
   / Best way to engage rotary cutter #17
   / Best way to engage rotary cutter #18
   / Best way to engage rotary cutter #19
I just got a new rotary/brush cutter with a slip clutch. I adjusted the slip clutch and just want to know the best way to start these up. I'm running a branson 3120 with pto switch. I know to run it 540 rpms but it seems to jump and bang around when I 1st engage it.
Should I keep the rpms down to engage it with the switch, then ramp it up to 540? Or are they ok to just start at 540?
I start my rotary cutter with the tractor at idle and spin the throttle up once the PTO is engaged. I inadvertently videoed the inside of the cab starting and running my rotary cutter.
Yale Electric Pallet Jack (A50514)
Yale Electric...
UNUSED X-STAR SKID STEER 72" LAND PLANE (A51243)
UNUSED X-STAR SKID...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51243)
UNUSED X-STAR 101"...
2016 Ram 5500 Chassis Truck, VIN # 3C7WRNAL2GG280521 (A50323)
2016 Ram 5500...
2002 Trotwood Trailer (A50515)
2002 Trotwood...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
