Bevelling Steel Pieces for Welding
   / Bevelling Steel Pieces for Welding #51
My 4x6 jet will cut to within a degree of perfectly square every time. It's how you set it up and how you break in your blades. $100 off CL and the previous owner put some metal through it too (it's well used).
1/4" needs a bevel if you can't get the heat in the puddle. I started on a 120v MIG, so I remember those days. I just got a 120v Hobart for field work in the woods and it's depressing when the thermal protection kicks in. :D Makes me miss my real welders back in the shop.
   / Bevelling Steel Pieces for Welding #52
For 2x2 square tube I would probably just leave a gap for welding.
If a bevel was required I would use the belt/disc sander if the piece was a manageable length.
Terry
   / Bevelling Steel Pieces for Welding #53
For 2x2 square tube I would probably just leave a gap for welding. If a bevel was required I would use the belt/disc sander if the piece was a manageable length. <img src="http://www.tractorbynet.com/forums/files/welding/429372-bevelling-steel-pieces-welding-image-351642216-jpg"/> Terry
Was thinking belt sander also on the 1/4" stuff with 60-80 grit?
Sent from my iPhone 5s 64Gb using TractorByNet
   / Bevelling Steel Pieces for Welding #54
I get more use out of this upside down on metal, than I ever did right side up on wood. A 60 grit ceramic belt removes metal easily and lasts a very long time.
   / Bevelling Steel Pieces for Welding #55
Was thinking belt sander also on the 1/4" stuff with 60-80 grit? Sent from my iPhone 5s 64Gb using TractorByNet
Eric. I'm embarrassed to say I'm not certain. The disc doesn't say, but it's quite a bit coarser than 60 grit. Maybe 36 grit. :)
image-3625969470.jpg Terry
   / Bevelling Steel Pieces for Welding #56
Eric. I'm embarrassed to say I'm not certain. The disc doesn't say, but it's quite a bit coarser than 60 grit. Maybe 36 grit. :) <img src="http://www.tractorbynet.com/forums/files/welding/429396-bevelling-steel-pieces-welding-image-3625969470-jpg"/> Terry
No worries you don't know you don't know; respect for not BS'in us
   / Bevelling Steel Pieces for Welding #57
A short video https://vimeo.com/130603533 Notice the light one handed pressure. Not a dedicated steel working sander. I'm sure a faster belt speed would improve material removal. Sent from my iPhone 5s 64Gb using TractorByNet
   / Bevelling Steel Pieces for Welding #58
Huh no replies...
   / Bevelling Steel Pieces for Welding #59
   / Bevelling Steel Pieces for Welding #60
View attachment 429396 Terry
Terry, changing the subject but looking at the background in your pic gots me to ask the question. What are you bending? Seems you have a nice set of bending tools.
2014 Dodge Charger Sedan (A52377)
2014 Dodge Charger...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
Case Maxxum 140 (A50120)
Case Maxxum 140...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A53426)
2014 HINO 338 26FT...
