4bt cummins jeep tj
   / 4bt cummins jeep tj
All cleaned up
Started welding the bracket
Todays progress
   / 4bt cummins jeep tj #105
Pretty soon you'll be mocking up motor mounts.
Factory jeep alt, ac comp and drive belt fit and are tight
Here is a closer look at the air con compressor mount that is not completely done
   / 4bt cummins jeep tj #108
Wow looks good! Are you upgrading axles or tranny to deal with extra torque?
Sent from my iPhone 5s 64Gb using TractorByNet
I broke the dipstick shroud so I replaced it with stainless steel
I am looking to do a full axle build l, currently looking for a good set of 44's that is not way over priced, the factory trans will remain till I break it then I will probably build a nv4500 and look for a dana 300 transfer case or atlas 2
2019 Chevrolet 2500 4x4 Extended Cab Knapheide Service Truck (A50323)
2019 Chevrolet...
2007 Generac QT06030AVAN 60kVA LP Generator (A50322)
2007 Generac...
2012 Hyundai Elantra Sedan (A50324)
2012 Hyundai...
Vermeer 840 Discbine (A50774)
Vermeer 840...
2011 PETERBILT 389 (A52472)
2011 PETERBILT 389...
2005 Jeep Wrangler 4x4 SUV (A50324)
2005 Jeep Wrangler...
