Is a 1967 Ford 2000 metric?
   / Is a 1967 Ford 2000 metric? #11
Should be metric. But who knows what has happened in the last ~50 years. Its possible the original 3/8 bolt was stripped, and since 10mm is slightly larger, maybe someone had a 10mm bolt and tap handy and made a simple and common repair.
   / Is a 1967 Ford 2000 metric? #12
I thought this would be easy to find out but not so much. I bought a 1967 (I think) Ford 2000 the other day and am going over it. The front nose bracket that connects the cowl to the front of the engine block was not attached. I used a 3/8 inch new bolt and it would not grab, so I assumed the holes were stripped. I found a different bolt -- too long -- and it seemed to thread in much better and I think it will hold. I checked the long bolt at the hardware store and I think its a metric M10-1.5 (not sure on the 1.5). So I'm wondering if that tractor is metric. I'll pull a couple of fasteners next time I'm at the farm and do some investigating but thought someone might know.
I've had some problem with the serial number - looks like a "C" followed by 18. So that would mean made in USA and I'd assume its SAE. However, I think one of the tires is original and it says "made in England." It has a CAV fuel injector.
Does anyone know if these were made in both SAE or Metric?
Also, what holds the radiator in place on the top? I see its attached by two bolts on the bottom. It looks like when I get the new bolts in the bracket the radiator fan shroud is going to be rubbing on the generator pulley.
Thanks in advance.
As previously stated, the major castings were SAE with the exception of some components. C should be the prefix as it was built in Michigan, but the engine was built in Basildon England.
   / Is a 1967 Ford 2000 metric? #13
Not so.
They were 7/16 UNC X 3/4" as stated above.
   / Is a 1967 Ford 2000 metric? #14
Not so.
The US tractors - at least through the Thousand Series - had engines built in the US.
They also built the same engines in Basildon for the EU market.
Later tractors, maybe starting with the 3600s or 10 Series all had engines built in Basildon.
They were all SAE bolts and nuts.
   / Is a 1967 Ford 2000 metric? #15
Not so.
Okay, I'll restate. They were Basildon Series Diesels (BSD), and were of English design origin and SAE fasteners.
   / Is a 1967 Ford 2000 metric? #17
Copied & pasted from the New Holland online parts store.
11 STUD Screw, Thumb, M8 x 16, Years: 01-JAN-65-31-MAR-68, Serial Range: Grille-Shell-Thumb 412575 $19.88 3 in stock
   / Is a 1967 Ford 2000 metric? #18
Dunno.
Photographed and uploaded from my junk drawers.
I do know a bit about threads - V sharp, ANS, ANF, ANC, square, acme, etc. Have cut many a set, both internal and external on a lathe.
Till this moment I would have put a pretty good bet they were 5/16X18.
Maybe someone knows if your metric size will fit my ANC.
PS,
Thumb screw is an original 1/65 to3/68 part.
   / Is a 1967 Ford 2000 metric? #19
Yep, that's what I was wondering. At almost 20 bucks a pop, I'd make the 5/16 work...
   / Is a 1967 Ford 2000 metric? #20
Not so.
Wow, dont know why I typed that. Case of fingers not typing what the brain is saying.
I think i either meant "should be SAE" or "could be metric"???
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2022 John Deere 8RX 410 Tractor (A53342)
2022 John Deere...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
WOODS RT48.30 LOT NUMBER 235 (A53084)
WOODS RT48.30 LOT...
