Is a 1967 Ford 2000 metric?
   / Is a 1967 Ford 2000 metric? #21
Not so.
The US tractors - at least through the Thousand Series - had engines built in the US.
They also built the same engines in Basildon for the EU market.
Later tractors, maybe starting with the 3600s or 10 Series all had engines built in Basildon.
They were all SAE bolts and nuts.
I'm not aware that any Ford tractor engines built 1965 and after were manufactured anywhere in the world other than Basildon, England. I welcome the opportunity to be educated on this topic.
   / Is a 1967 Ford 2000 metric? #22
Rick, I thought they were built in Romeo.
   / Is a 1967 Ford 2000 metric? #23
Copied & pasted from the New Holland online parts store.
11 STUD Screw, Thumb, M8 x 16, Years: 01-JAN-65-31-MAR-68, Serial Range: Grille-Shell-Thumb 412575 $19.88 3 in stock
Originally that was an SAE fastener, but since Fiat took over, some sheet metal fasteners have been substituted with metric fasteners where they will work to eliminate duplication of parts. When used in spring/clip nuts as this is, the thread isn't going to matter.
If you go aftermarket, A- D4NN8B151A are about $7.00 each.
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2013 JACK COUNTY 130BBL VACUUM TRAILER (A52472)
2013 JACK COUNTY...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2015 FORD F-450 SERVICE TRUCK (A52472)
2015 FORD F-450...
DOOSAN G70 PORTABLE GENERATOR (A52472)
DOOSAN G70...
