Pulling wire in conduit
   / Pulling wire in conduit #21
I never pull wire. You go to all the work of digging the trench, installing the conduit, filling the trench and then work so hard on getting the wire through the conduit. It's just so much easier to dig the trench, unroll the wire next to the trench, slide the conduit over the wire and bury it once all the conduit is is in place.
Eddie
Very true, the only thing to be careful about is PVC glue getting on the wire. I think if you are careful it's fine. When I have done this, I only put glue on the male end of the conduit, and kept it back from the lip about 1/2" or so. That way, when sliding the female end over, there shouldn't be a reason for the glue to get inside the conduit.
   / Pulling wire in conduit #22
Used wire lube to pull the wire. The PIA is that size wire and especially 3 twisted together is like wrestling with a elephant trunk. But add in a hot humid day, mosquitos, ants, 2 snakes, muddy ground from an ungodly amount of rain we've had here, roots the size of your arm and people (neighbors mainly) stopping by but not offering to help.
Someone asked if I was missing a wire, no with electric from the rural coop here its 2 hot wires and a neutral.
You missed the ground and the conduit is undersized. Will not pass electrical inspection.
   / Pulling wire in conduit #24
It must some local sub standard code . The a national building code in Ontario would have the inspector fail the installation. Depending on the wire 2-1/2 or 3" for most types of cable.
   / Pulling wire in conduit #25
Texas Ken might be talking about 2 hots and a grounded conductor (neutral) being permissible as part of a service lateral conductor from the utility (and then the neutral is bonded to the premises' ground bus at the first disconnect) , whereas a 2 hots, neutral and a ground would be required when running a feeder circuit from a house panel to a sub panel in a auxiliary building.
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
Woods 1800 Batwing Mower (A59814)
Woods 1800 Batwing...
2009 Hyundai Sonata Sedan (A59231)
2009 Hyundai...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A56438)
2023 Top Air ATV...
Electric Golf Cart (A56859)
Electric Golf Cart...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
