Chigger Season
   / Chigger Season #41
I know this sounds crazy but try Listerine mouth wash. It is scary how good it works for mosquitos, flies, and chiggers! Just put it in a spray bottle and soak yourself.
   / Chigger Season #42
I always seem to get the bites under my socks so I just wear the ankle socks when the chiggers kick up. ... To me, the bites are alleviated and effects shortened by breaking the pustule head and slathering on rubbing alcohol - 90% if possible. After an hr or so a crust forms proud. I rub them off with the palm of my hand and apply more alcohol. larry
This is my treatment of choice. Only I apply the rubbing alcohol till it stops burning. Then rub off crust and re-apply. Applying rubbing alcohol to attached ticks also help loosen them.
Growing up I was the only one in the family to get chiggers. We could all walk through the same area and only I would have them. Moms solution was a bath in bleach water when we got home.
Once I got old enough to start working I found that if my boots smelled of diesel fuel then I no longer was the one to get ticks or chiggers. I will still cover my boots in diesel fuel a few times a year. Gear oil also works. There is something to using your pants as a rag when working with oils.
   / Chigger Season #43
Or just use OFF. :D
   / Chigger Season #44
This is what I do except for the alcohol part. :shocked::laughing::laughing::laughing: Benedryl gel helps to stop the itch though.
I have heard from a few people about the bleach bath but I never could figure out how much bleach in how much water. :shocked: Seems like that would be important and given what bleach does to skin, I was not inclined to try the bleach bath. :laughing: However, I do see some logic in that bleach would work since it dries out the skin.
Later,
Dan
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2008 DOOSAN G25 GENERATOR (A53843)
2008 DOOSAN G25...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
Mohawk 12,000lb Two-Post Electric Auto Lift (A54811)
Mohawk 12,000lb...
