LS XR3037 Compare To What Kiot, Kubota
   / LS XR3037 Compare To What Kiot, Kubota #1
Hdoilcan
Gold Member
USA
2018 KIOTI CK3510SE CAB, 2475L BACKHOE, 72 BOX BLADE, 72 REAR BLADE, 72 LANDSCAPE RAKE, 1,250 LB 55 GAL DRUM BALLAST, 2018 FERRIS IS 700Z, 26HP 810 VANGUARD ENGINE
I'm wondering what Kioti and Kubota model compares most to the LS XR3037 overall and footprint.
   / LS XR3037 Compare To What Kiot, Kubota #2
Off the top my head, Kioti CK35, DK40, NX4510. Kubota L3800, L3901, L3560,L4260.
I was hoping more towards the size of the ck35. I was going to purchade the ck35 and thought let me just check out the LS tactors. The ck35 I think would be perfect except for the loader capacity. The LS loader capacity is about 1000lbs more so I think tomorrow is the day to pull the trigger.
   / LS XR3037 Compare To What Kiot, Kubota #4
The XR3037 compares to the Kioti DK40 and the Kubota Grand L 3560. All three of those are premium tractors with extra features not found in the more basic machines.
   / LS XR3037 Compare To What Kiot, Kubota #5
Just took a quick look, the LS is gear only....lots more capable than a 35 horse unit...But, the DK 40 is quite a bit more tractor,in all aspects, Weight, pto hp, loader lift, and three point lift, and comes in gear or hydro, some links to compare...:) A nice cross between the 30 and 40 horse frame sizes, but really does not compete imo :)
XR3037 ォ LS Tractor USA
DK40SE Utility Tractor | Kioti Tractors
DK40SE HST Utility Tractor | Kioti Tractors
   / LS XR3037 Compare To What Kiot, Kubota #6
No... The xr3037 is available with a 3 range hydrostatic trans as well.
I think you meant the now defunct DK35...not the DK40. The 40 is a half class up from the xr3037... & is comparable to the LS xr4040.
   / LS XR3037 Compare To What Kiot, Kubota #7
That really is a pretty big difference. The LS max height is 2.5" lower, so the actual difference in lift capacity is closer, but still probably 800lbs or so in favor of the LS.
   / LS XR3037 Compare To What Kiot, Kubota #8
. . . I think you meant the now defunct DK35...not the DK40. The 40 is a half class up from the xr3037... & is comparable to the LS xr4040.
I meant the DK40 since the DK35 went extinct a few years ago, but I guess the DK40 is now extinct too. And, yes, you are correct that the DK40 is more tractor.
   / LS XR3037 Compare To What Kiot, Kubota #9
Your right pappy, just looked again at the web site, and seen the LS hydro available.
To bad they tainted the DK name with what they are now calling the DK10 .
The DK SE series was one of the best values in tractors Kioti ever offered.IMO
They should have kept that marketing concept, You have to pay extra now for most of the things the DK SE came with stock..no reason not to look elseware now....Big mistake they made IMO:thumbdown:
   / LS XR3037 Compare To What Kiot, Kubota #10
I agree it was better from a marketing standpoint to have the extras included, but your comment fails the logic test.
The "extra" things are rear remotes, the rear windshield wiper, and the stereo...that's it. For $1K you can get two remotes, the wiper, and the radio added to an NX.
Those things weren't free on the DK SE series, so you were paying that same $1K (ballpark), but it was included in the standard price so it wasn't obvious. If they weren't standard on the DK SE, the starting price would have been $1K lower. If they were standard on the NX, the price would be $1K higher. In the end, there's no difference to the buyer....you're paying for them either way, it's just whether you know about it or not.
You still can save multiple thousands of dollars buying an NX compared with equivalent models from most of the other manufacturers...having those couple of extras be separate line items didn't change that.
JOHN DEERE 650 TRACTOR (A52708)
JOHN DEERE 650...
Hydraulic spike driver (A56435)
Hydraulic spike...
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
1999 Dodge Ram1500 ST Ext. Cab Pickup Truck (A56858)
1999 Dodge Ram1500...
20 UTILITY TRAILER (A55745)
20 UTILITY TRAILER...
