Briggs 16hp twin won't fire
   / Briggs 16hp twin won't fire #1
farm boy00
Howard City, MI
John Deere M&MT, Case 1030 comfort king, Sears ST16, Craftsmen 6000, homemade articulation mini-loader
My Briggs and Stratton 16hp twin cylinder industrial engine won't fire. I parked it last fall with a bad coil. Just replaced the coil the spark plugs and now it won't fire. It don't even act like it's firing. Any ideas???
Attached are the info for the motor
I have dumped gas down the carb. I have tested for spark and got it
   / Briggs 16hp twin won't fire #3
Does it seem to have normal compression? If you have spark (at the correct TIME) and you've at least force-fed it some fuel, you should get SOMETHING. Just how much fuel did you dump in? If it was enough to completely wet the spark plug, consider it flooded. Try maybe a teaspoon full or less, or a squirt of ether and let us know what it does.
- Jay
- Jay
We couldnt even get it to flood out. We purposely tryed too and couldnt flood it
   / Briggs 16hp twin won't fire #5
What were the symptoms last fall? Why the bad-coil diagnosis? Do you have good compression?
Jim
   / Briggs 16hp twin won't fire #6
Sheared flywheel Key? bjr
   / Briggs 16hp twin won't fire #7
   / Briggs 16hp twin won't fire #8
How did you determine that you had a bad coil? Are you sure you have the plug wires on the correctly?
   / Briggs 16hp twin won't fire #9
If the magnets in the flywheel are rusty, clean them with sandpaper. It will make a difference.
I determined the bad coil because it would run for a min quite cool down repeat.
There is a little rust on the fly wheel. I'll clean it up
Got the fly wheel cleaned up. But there is a wire running up from the motor by the oil dipstick. Any ideas that that could cause the
problems??
   / Briggs 16hp twin won't fire #12
Cleaning a rusty mag coil/magnet makes one feel good but a little rust on those components have no affect on magnetic flux. It is really helpful if you post engine model numbers. ASSUMING you may have a flathead opposed twin, 40 series engine, are you sure you installed the coil correctly? Plug wires exit coil heading towards the back of engine, double back in opposite direction coming out then on carb side of engine where plugs are.
Walt Conner
Walt Conner
Yes i do have that style. Sorry about not positing earlier
Can you explain what you mean a little more. I did the the shorter spark plug wire to the closer plug
   / Briggs 16hp twin won't fire #14
That wire, if it runs under the flywheel is the generator wire with a diode in it. Sounds like your coil is grounding out. When I overhauled my Dad's 16 hp B&S twin in his Gilson, I ripped the coil out and put in electronic ignition.
hugs, Brandi
hugs, Brandi
Can you go into more detail about the wire and the coil grounding out
   / Briggs 16hp twin won't fire #16
You should have a wire from under the flywheel to the coil. Find that wire and see if it is grounding out. If I remember right............that wire goes to the switch to kill the engine. Also, after watching this Youtube video here......https://www.youtube.com/watch?v=PfRP4QW2ppE I remember the air gap on the coil is important. Very important. Did you check your points and their gap. This link might help..........Replacing the ignition
If you got to remove the flywheel.............they can be stuborn. I bent/broke a couple of pulley pullers on it. I finally bought a B&S twin flywheel puller. Even then it took a lot of pounding on the edge of the flywheel.
hugs, Brandi
   / Briggs 16hp twin won't fire #17
Oh yeah...that wire should run from the coil to the condenser. When I was younger, my brother and I would sometimes pinch the wire with the cover to the condenser at the points on our mini bike engines.
Electronic ignition would do away with the points and condenser.
hugs, Brandi
hugs, Brandi
It's a electric sssooo I'm guessing that's just there for nothing then
   / Briggs 16hp twin won't fire #19
Find where that wire goes. Check to see if it is grounded. If it is, that might be your problem. It would be grounding out the spark. It's really hard to trouble shoot something you can touch while a 1000 miles away.
hugs, Brandi
hugs, Brandi
I tried yup check but i can't find the end cause it goes behind the flywheel
KSI Conveyor (A56438)
Kubota B21 TLB (A60462)
Kubota B21 TLB...
23" QUICK ATTACH EXCAVATOR BUCKET (A60429)
23" QUICK ATTACH...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2012 DOOSAN G25 GENERATOR (A58214)
2012 DOOSAN G25...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
