Weatherproof garage doors?
   / Weatherproof garage doors?
... Nothing froze this year in the garage despite the very harsh wind and cold temperature. I hate burst frozen beer cans spewing suds all over. What remains tastes awful.
Hmmm... you're in Michigan and nothing froze? Great looking doors. The garage/studio we're building is unattached and I had assumed that when temps outside got down to around 20 below that any freezeable materials inside would freeze-- absent any supplemental heat source. I guess there's a lot of variables...
Know what you mean about frozen beer-- not a good thing! :D
I have 2 ten foot tall garage doors that are insulated. They are facing east which helps a lot. The rest of the garage/shop is insulated and stays toasty warm when I use heat. Very quiet also.
Dave
What kind of heat are you using in the garage Dave?
   / Weatherproof garage doors? #13
When you park a car and a truck fresh off the highway into a well insulated garage, the heat source and mass of the vehicles will provide a few hours of comfortable warmth in the building air (not necessarily the structure). This can be a problem if the slush from the vehicles then melts and tries to exit under the doors. There can then be a frozen door, so have a properly drained floor away from the door openings. If you have a refrigerator in the garage for that Summertime refreshment collection, the thing won't work properly and the defrost cycle will give you a headache.
I just put a cupola up on the garage roof, so now I have to plan on some type of seal to keep the heat from baling out in Winter. The cupola does a wonderful job of letting trapped heat escape. It has to be screened to keep bugs and birds out, too.
   / Weatherproof garage doors? #14
When you park a car and a truck fresh off the highway into a well insulated garage, the heat source and mass of the vehicles will provide a few hours of comfortable warmth in the building air (not necessarily the structure). This can be a problem if the slush from the vehicles then melts and tries to exit under the doors. There can then be a frozen door, so have a properly drained floor away from the door openings. .
Floor sloped away from the door? That's a new one to me. Floor slabs around here are typically either level or sloping towards the door. If you have in-floor drains, that changes things but opens up a whole other can of worms.
If the shop is heated, there should be no worry about frozen doors
   / Weatherproof garage doors? #15
I have an office and game room elevated 2' above and to the side of the shop area. I use a wood burning stove for heat. My shop hasn't gone below 40 degrees even without the stove going.
   / Weatherproof garage doors? #16
I like using roll up doors, because they don't interfere with anything when you roll them up. I used TracRite doors on my shop. They come with options for insulation, draft seals and brush seals if you want them.
   / Weatherproof garage doors? #17
I don't see any mention of insulation options on that website. Several different choices of weather/wind seals but that's it. I've never seen them up here on a heated building and can't even guess how one could be insulated. Even if you could, the roll would be 4' diameter when its all rolled up.
   / Weatherproof garage doors? #18
It's part way down this page. TracRite Accessories It's just foil lined bubble wrap, glued to the inside. I have it on both of my shop doors. It actually works surprisingly well.
On my old metal doors, during the Texas heat, you felt like you were standing next to a radiant heater inside. With these, I don't feel any heat radiating through.
What's nice with the roll-ups is that they don't interfere with any of your inside shop lights. With the partition doors, when they raise up, they usually obscure the ceiling lights.
I think I paid $400/ea. for my 8' x 8' roll-ups with insulation, draft seals, brush seals and lock sets. You can install them in about an hour with 2 people.
   / Weatherproof garage doors? #19
Missed that page when I was looking. I can see bubble wrap working in Texas to keep heat out, that would be what, 40 deg F temp differential? We are often 100-110 deg F difference from outside winter temp to room temp. Bubble wrap ain't going to cut that. Not blocking lights is a positive I hadn't thought of for them.
   / Weatherproof garage doors? #20
I have clopay insulated garage doors on my garage and barn. Haven't insulated the barn yet, but went ahead and put in insulated doors when I built. I like them.
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
UNUSED FUTURE 32" HYD TILTING BUCKET (A51248)
UNUSED FUTURE 32"...
2016 HAMM HD+ 120I SMOOTH DOUBLE DRUM ROLLER (A51246)
2016 HAMM HD+ 120I...
KUHN GMD-310-HD LOT IDENTIFIER 38 (A53084)
KUHN GMD-310-HD...
2022 John Deere 8RT 410 Tractor (A53342)
2022 John Deere...
