Property Gate Control/Video
   / Property Gate Control/Video #11
The radios come with POE injectors. Trees could be a problem and you should test it out. That's a pretty short distance for these radios, but without seeing the site I cannot advise. I have installed the units on a 15' mast at the gate, which also had a solar light and PTZ camera attached and the base unit on a high point of the house to shoot over trees. I've also just aimed one from a stable a half mile to the receive unit sitting on a desk in the house and it worked fine with some trees in the path. Most auto-gate companies have IP boards for the controller if you ask. They used to use a dedicated phone line installed at the gate, but who wants to pay for that?
   / Property Gate Control/Video #12
If you have the trench passing thru, I'd HIGHLY recommend installing at least an empty pipe for future use. One inch well pipe would be fine - just be sure to use external connectors. And, while I'm a fan wireless, generally once fiber is installed, it just works, regardless of rain, snow, sleet, or hail.
Regarding gate controller, you really just need the ability to close a contact for remote operation. Common to use a garage - door style wireless for your own vehicles, and either have a keypad for visitors, or let visitors call you in order to gain entry. There are several 'contact over ip' products out there, some with matching mart phone apps.
Go to doorking.com - they show a wide variety of gate products.
   / Property Gate Control/Video #13
Yes I would put in a 1" spare pipe as well. Over that length I would also have at least 4 pull boxes and install a 600 lb Mule Tape. That said, I would charge approximately $4,500 (plus or minus $500) to pull a 2500' 4-strand OSP fiber into an existing conduit bank here in the Dallas area. This is what I do for a living. The price includes the fiber, termination, testing with hard and soft copy certification, and media converters for both ends. Also included in the price is OTDR reel testing prior to product placement. This insures that you don't pull a half mile of worthless glass just to pull it all out and start over. In other words, figure on at least $5000 additional cost using fiber.
I was having about 1000' of fiber installed during a construction project. The installers ran over the spool with a skidsteer and installed it anyway. Needless to say - they had to pull new fiber.
   / Property Gate Control/Video #16
What is presently the best solution, short of a chainsaw, for getting through trees?
Shoot over them is best. Or you can go 900Mhz if there are no Walmarts within 1/2 mile of you. 900Mhz will go through some foliage. If you are not sure about a link there are guys like me who will do a site survey which includes interference testing and setting up an actual test transmitter to measure the throughput at various frequencies. I charge hourly for that, but waive the charge if they buy the link solution.
   / Property Gate Control/Video #17
Thanks, reading the Amazon reviews of the Ubiquiti Nano Station M900 sounds like I'll by two of them for a fall project.
Is the M900 a weather resistant outdoor unit?
   / Property Gate Control/Video #19
Yes it is. I put one up inside a 3 story office in Tampa last year and beamed it to a clinic about 3/4 mile away through some pine trees just to see if it would work. Worked fine and I think the base unit is still just sitting on the window sill.
OK ... sounds like a great product. I'll have to pick out a good POE switch and figure out the right solar setup to get everything going.
Another question :) I will have one unit at my gate and another at my house. That leaves the barn which is about the same distance away from the house but on the far side of my property. Can I aim the 2 remote sites at the same house receiver?
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A53472)
2019 New Holland...
480/70R38 LOT IDENTIFIER 122 (A53084)
480/70R38 LOT...
(APPROX 24) 2" X 3" X 49" THICK TUBING (A51247)
(APPROX 24) 2" X...
2018 BIG TEX 70CH 84" X 20' CAR HAULER TRAILER (A51247)
2018 BIG TEX 70CH...
WOODS RT48.30 LOT IDENTIFIER 219 (A53084)
WOODS RT48.30 LOT...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
