3 pt shaft w shear pin
   / 3 pt shaft w shear pin #1
emery
Western Mass
Kubota b9200
Looking to buy 3pt shaft with shear pin protection. Would appreciate if someone could pass on dealer or manufacturer info. thanks
   / 3 pt shaft w shear pin #2
Emery
Your not likley to find a shaft with a shear bolt,in 18 yrs. on the farm and last 20 yrs. on heavy equipment,i have never seen a shaft with sheer bolt.Sheer bolts are always on eqiupment just after the pto shaft,and before the gear box on machine.
   / 3 pt shaft w shear pin #3
I have a LUCKNOW rear snow blower that has the shear pin immediately behind the front U-joint up by the tractor's PTO. Right behind the U-joint and part of the casting are two lobes that a 1/4" diameter, 1-1/2" long bolt join together. It is somewhat of a pain because the PTO shield makes access difficult, especially in the winter and dark. LUCKNOW is in Ontario, Canada. I brought it 10 years ago.
RCH
   / 3 pt shaft w shear pin #4
My snow blower has the same setup. Shear bolt on the tractor PTO end of the shaft. Just bought it last year, but it was a leftover model.
Depending on what you plan to use it for, you should consider a slip clutch if you think you will break the bolts often. They get to be a pain of they are breaking often as they do on my snow blower every time I pick up a rock.
   / 3 pt shaft w shear pin #6
RCH
That set up is just backward from every shear bolt set up I have ever seen (mostly bush hogs) where the shear pin is at the gear box where the shaft is connected. I suppose the shaft could be turned around 180 and the shear plates installed next to the tractor like in your snow blowers, but that would seem to make everything harder to get to when replacing the shear bolts. I am just wondering if someone just set up these two snow blowers PTO shaft backwards from the standard way.
   / 3 pt shaft w shear pin #7
2001 called and wants their thread back. :laughing:
   / 3 pt shaft w shear pin #8
Yup, and after almost 2 more years is still relevant and just the information I needed.
(2) CASES OF PEPSI GLASSES (A58374)
(2) CASES OF PEPSI...
FIMCO 60 GALLON SKID MOUNT SPRAYER (A52708)
FIMCO 60 GALLON...
2022 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
2012 KIA Optima (A56859)
2012 KIA Optima...
SHOP MADE MANIFOLD TRAILER (A58214)
SHOP MADE MANIFOLD...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E88NFB46449, Extended Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
