I didnt see anyone here propose unsafe behavior. And didnt see anyone here propose doing something that was not up to code. So who cares if we dont use the correct terminology.
The fact that 240v uses 2 hot "legs" and some of us refer to them as phases....who cares. So when I say on a MWBC as long as the neutral is share between hots on different phases, while it may not be correct terminology, it is still correct wiring and NOT unsafe. And it seems to make more since than saying "make sure the neutral is shared between two different hot lines". Because anyone else googling and/or reading this thread may get the wrong assumption that "line" just means two different 120v lines, and not necessarily two that are 180 degrees out of "phase"
When I wire up a phase converter or VFD with the two 240v legs, is it okay to call them phases then? or is it only okay to call the two lines (+ created leg) phases AFTER the converter?
My questions and reasons for starting this thread were to better understand a MWBC. I know how to wire them, and know how they work, and have worked on them many times in the various factories I have worked at. Just never paid attention to how GFI's get tied in. So with the help here, I now understand.
I also didnt know if code allowed anything other than white for neutral. This is my barn, with no inspections or code enforcement. I could use pink or brown, or blue, freaking rainbow color wire and no one can stop me and no one will care. But even though I am not forced to follow code, I want to. That question was answered as well.
Back on page 7 I said I had my mind made up. But never said which way I was going to go (intentionally). I am not gonna be doing a MWBC. I would only be saving basically 1 run of wire around the shop. While I would save 2 wires in theory, thats only to the first outlet, which is only 3 feet from the main. Then I would have to add a neutral for that GFI circuit. With all the circuits being GFI, everytime I start a new circuit, I add a ground. So only saving what is equal to 1 run of wire, and risk of 240v, I am going to do a typical install.
