Anyone put two sump pumps in one basin?
   / Anyone put two sump pumps in one basin? #21
Im not sure if anyone has mentioned it but with 2 pumps its a good idea to have each on a separate circuit in the event the primary pump fails and trips a breaker.
I concur, was called to a flooded basement just because when second pump came on and started working hard, tripped breaker and took out both, otherwise serviceable, pumps.
   / Anyone put two sump pumps in one basin? #23
The weep hole is to prevent the pump from getting airbound above the impeller and unable to push the head above the check valve (can't pump air with a sump). (GFCI's).
That's the answer I was looking for. A hole above the check valve doesn't make sense. The sump pumps I have must have the air relief built into the pump since my check valves screw directly to the pump outlet.
   / Anyone put two sump pumps in one basin? #24
jjsjeff, avondale, cqaigy, kc5dlo, brb hand, brown 40, ultra runner: All good information and very helpful suggestions. Thanks.
Mark
   / Anyone put two sump pumps in one basin? #25
and if you can put that spare to work, all the better.
The trouble with putting the spare (of anything) to work is eventually you incorporate it into normal routine and it is then no longer a spare. ;)
   / Anyone put two sump pumps in one basin? #27
I don't have a sump pump, but I have seen "backup pumps" that run off the city water system if you're on city water. Rather than trying to explain it, here's a link to a company that makes them and another link to a video for another company's system.
My neighbor has a water powered pump as a backup (someone thought it would be a good idea to build a house above a spring so his pumps are well exercised), he likes it.
Aaron Z
   / Anyone put two sump pumps in one basin? #29
Maintenance schedule??
The amount of time spent from when something breaks down figuring out when you'll get around to fixing it?
I've seen lots of pits with 2 pumps and also 2 pits side by side with dual pumps. I have a pedestal style primary pump and a battery backup mounted inline in the discharge pipe. Check valves on everything. Never heard of the weep hole in the pipe. I always add a vent of some sort on the horizontal run that the vertical pipe stays full above the check valve and not draining back into the pit but the horizontal pipe can drain fully
   / Anyone put two sump pumps in one basin? #30
My sailboat had two electric pumps and a manual one... it was a dry boat... just wanted to be sure sailing the waters of the SF Bay...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
Mayrath 13 x 62 Swing Away Auger (A59814)
Mayrath 13 x 62...
Cushman Cart (A59231)
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2014 KENWORTH T800 HYDRO EXC VACUUM TRUCK (A59823)
2014 KENWORTH T800...
2016 Ford Taurus AWD Sedan (A59231)
2016 Ford Taurus...
