8' disc behind L3540?
   / 8' disc behind L3540? #11
I pull an old 8' Tufline behind my L3240 but have to engage the 4 wd if the ground is a little heavy.
   / 8' disc behind L3540? #15
Pans measure 19" front and rear, scalloped all around.
Ok, someone made mention of pulling the disc through a narrow passage, and with the trees I have here I've decided to try to find a decent 6-6 1/2' disc.
Whats anyone know about the Linebach line.I know they are now out of buisness, but I found a mildly uses 6 1/2 foot one ,heavy box construction, notched pans, with the big threaded adjusters for $1200, they even have a new one of the same but want $1600.. a little to rich for my blood.
Sounds like a job for your loader to me. Got any pictures of each set? They are a long way from me but I might be interested in the set you don't buy. Eight foot does sound like a lot for a L3540. Is it a 3 Point hitch setup or drawbar towed. If it is 3PH can your hitch pick it up?
Sorry no pics, Wade is the guys name he owns Griffin Tractor & Equipment, lots of stuff, give him a call at 704-221-8210
   / 8' disc behind L3540? #18
As you adjust the disc gangs, total width of the Disc Harrow changes. The LESS aggressive, straighter, the gangs are set, the greater the total width of the implement.
   / 8' disc behind L3540? #19
Have you looked at everythingattachments?
Everything Attachments XTreme Duty Deluxe Box Frame Disc Harrow
If you go up to 7' you could get into their "large" line with 1 1/8" shaft and 4.5mm pans Be sure to look at disc thickness too, they very.. Lots of options with disc harrows..
Everything Attachments XTreme Duty Large Deluxe Box Frame Disc Harrow
I have their 24/20 and am happy with it. I prefer the design where the gangs protrude out of a solid side plate rather than the "sandwich" approach.
Yes I have.. the larger ones are getting way out of my price range ( I do this stuff for fun, I don't make money with it) the smaller ones are just a bit out of range, and then I would have to figure out how to get it here..
HYDRAULIC SKID (A52472)
HYDRAULIC SKID...
Two Post Car Lift (A50120)
Two Post Car Lift...
2008 Ford F-250 XL (A50120)
2008 Ford F-250 XL...
Electric Mobility Scooter (A51694)
Electric Mobility...
1000 Gallon Concrete Fuel Tank (A50774)
1000 Gallon...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
