8' disc behind L3540?
   / 8' disc behind L3540? #11
I pull an old 8' Tufline behind my L3240 but have to engage the 4 wd if the ground is a little heavy.
   / 8' disc behind L3540? #15
Pans measure 19" front and rear, scalloped all around.
Ok, someone made mention of pulling the disc through a narrow passage, and with the trees I have here I've decided to try to find a decent 6-6 1/2' disc.
Whats anyone know about the Linebach line.I know they are now out of buisness, but I found a mildly uses 6 1/2 foot one ,heavy box construction, notched pans, with the big threaded adjusters for $1200, they even have a new one of the same but want $1600.. a little to rich for my blood.
Sounds like a job for your loader to me. Got any pictures of each set? They are a long way from me but I might be interested in the set you don't buy. Eight foot does sound like a lot for a L3540. Is it a 3 Point hitch setup or drawbar towed. If it is 3PH can your hitch pick it up?
Sorry no pics, Wade is the guys name he owns Griffin Tractor & Equipment, lots of stuff, give him a call at 704-221-8210
   / 8' disc behind L3540? #18
As you adjust the disc gangs, total width of the Disc Harrow changes. The LESS aggressive, straighter, the gangs are set, the greater the total width of the implement.
   / 8' disc behind L3540? #19
Have you looked at everythingattachments?
Everything Attachments XTreme Duty Deluxe Box Frame Disc Harrow
If you go up to 7' you could get into their "large" line with 1 1/8" shaft and 4.5mm pans Be sure to look at disc thickness too, they very.. Lots of options with disc harrows..
Everything Attachments XTreme Duty Large Deluxe Box Frame Disc Harrow
I have their 24/20 and am happy with it. I prefer the design where the gangs protrude out of a solid side plate rather than the "sandwich" approach.
Yes I have.. the larger ones are getting way out of my price range ( I do this stuff for fun, I don't make money with it) the smaller ones are just a bit out of range, and then I would have to figure out how to get it here..
Kubota ZG327 (A50120)
2016 Chevrolet Traverse 1LT SUV (A50324)
2016 Chevrolet...
Kubota RTV1100 Utility Cart (RUNS) (A50774)
Kubota RTV1100...
2018 Ram 3500 Reading Service Truck with Liftgate (A50323)
2018 Ram 3500...
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
2006 Nissan Titan Crew Cab Pickup Truck (A50323)
2006 Nissan Titan...
