Plate thickness for pintle hitch
   / Plate thickness for pintle hitch #31
As I remember it sank because they left open holes on the sides of the pontoons while they were working on it, but it was a long time ago. Maybe they let it sink on purpose so they could collect the insurance to build a new one.
   / Plate thickness for pintle hitch #32
I recall they were sandblasting the pontoons with water/sand, and using the chambers for the dirty water storage, which lowered them in the water, making the access holes closer to water level. Then a storm came up and everybody left without covering the access holes. Waves splashed into the (lowered) holes and swamped the one. When it sank it pulled the next pontoon further down into the water, and the waves filled that one too, and on?.
Hey weren't we discussing a fictitious Harbor freight MIG welding 3/4" plate on a dumptruck thats going tow a 20,000 lb excavator past the daycare where all the attorneys take their kids?
   / Plate thickness for pintle hitch #33
you can not say it any better than this!
except, you forgot the D.O.T. officer that has his kids there too.
And the traffic court judge that has grand kids there.
someone help me here. how many charges of wreckless endangerment would that be?
or would that be negligent homicide?? We will get to see it all when the news helicopter flys over... you know while they are still finding all the bodys and doing a head count of all the kids.
but we don't know anything about welding and penetration and safety. so do what you want.. it is just our "opinion" right?
   / Plate thickness for pintle hitch #34
433422d1437247301-plate-thickness-pintle-hitch-image-jpg
Those 2 welds at the top (made by the fictitious HarborFreight MIG) don't look sufficient but the pintle hitch fell off first, so what the heck? Hey that thing's got no taillights! The D.O.T. officer is getting out his ticket book!
   / Plate thickness for pintle hitch #35
Wow. So the "bridge" actually floats on the water? Interesting method. Never seen it, but from where i have lived that is not surprising.
   / Plate thickness for pintle hitch #36
Common here in the great Northwest! Three large bridges more than a mile long over both fresh and salt water.
   / Plate thickness for pintle hitch #37
I could really stack a bead in this one with gaps this big. If you insist on doing this job yourself, first grind all the metal clean and shiny. no paint, no contamination. crank up the amps all the way on your hf welder. and starting at the bottom, run a bead. this lets the molten metal sit on a shelf. Then take a 4" angle grinder and grind it smooth and look for undercut(google it). "if" you dont have decent undercut, you should get another welder as many of us have said. but if you dont get undercut, and you want to be hard headed and weld it yourself anyways then weld the joint from both side and use 3/4" gussets and heavy angle iron brackets.
While you are welding (if you dont care about little Mary at the daycare) use gas shielding and not flux core wire and get the tip as close as possible for maximum penetration.
make sure you dip the tip of your mig in jelly so you dont crap up your tip.
then after you do all this welding and get your hitch on there, I want you to remember little suzie in the honda civic next to you.
and compare your welds to the ones on the hinge pins right above you.
(the safe ones) if you welds dont look like that then you shouldn't be doing it.
tip of welder closer to metal = more penetration and hotter weld
tip of welder a little further back = less pen and more filler weld
tip of welder in a pros hand = little suzie get to see mommy after work.
and good luck getting to the slack adjusters in your brakes.
   / Plate thickness for pintle hitch #38
   / Plate thickness for pintle hitch #39
Maybe you can reach them thru the brakelight holes.
2008 Ford F-450 Crew Cab Service Truck (A52377)
2008 Ford F-450...
2015 Honda Odyssey VAN (A51694)
2015 Honda Odyssey...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2014 KOMATSU PC490 LC-10 CRAWLER EXCAVATOR (A52576)
2014 KOMATSU PC490...
2008 New Holland B110 MFWD Loader Backhoe (A53472)
2008 New Holland...
1262 (A50490)
1262 (A50490)
