killing weeds need help.
   / killing weeds need help. #1
jack707
up North wisconsin
farm trac 555
The field I'm going to put my food plot is loaded with WEEDS! I tried crossbow but that just turned a few brown and nothing on the rest. Yesterday I was talking to someone at the local co op who told me to use 2-4-d ams ( granules) and roundup ok so I bought all mixed with water in the sprayer and this AM NOTHING! what did I do wrong?.
   / killing weeds need help. #2
Patience! It takes a few days for them to work, a week or more to kill.
   / killing weeds need help. #3
First, Crossbow is a broadleaf herbicide -- it won't kill grasses. How many days since you sprayed the Crossbow? How many ounces of Crossbow/gallon of water did you use?
Roundup (glyphosate) is non-selective but is relatively slow acting -- you shouldn't expect to see any results for 10+days or so from the glyphosate. 2 4-d is a broadleaf herbicide and is an ingredient in Crossbow. It's relatively fast acting on some weeds, but you have to give it some time.
Also, my experience is that herbicides tend to work faster in the spring.
Steve
I use 3 oz. or so of crossbow in a one qt. sprayer last week. I guess my question is the ams I have is not liquid so how much do I use? since no directions were on the bag and can I use it with 2-4-d also.
   / killing weeds need help. #5
Is that a typo? Per the Crossbow label, I use 2 ounces per gallon of water when I am spraying privet in grassy areas. You need to read the Crossbow label to determine the appropriate rate for your weed species.
Regarding the ammonium sulfate, check the pdf at weeds.nmsu.edu/pdfs/AMS_use.pdf.
Steve
   / killing weeds need help. #6
Agreed on the glyophosphate, after a week you'll some dead, in 10 days you'll smile.
   / killing weeds need help. #7
I hope you did not mix 24d and ru together ?
   / killing weeds need help. #10
If one is using Glyphosate, why would one want to add 2-4-D?......just wondering.
2017 FORD F250 SUPER DUTY EXT CAB SERVICE TRUCK (A53843)
2017 FORD F250...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
CAT Skid Steer (A50322)
CAT Skid Steer...
2020 KUBOTA SVL95-2S SKID STEER (A52706)
2020 KUBOTA...
PENDING SELLER CONFIRMATIONS (A54607)
PENDING SELLER...
