radial arm saw plasma cutter
   / radial arm saw plasma cutter #1
Rednic79
Winnipeg, Manitoba, Canada
Homemade
hey, i'm half way though this plasma table project and would be interested to know what everyone thinks about it and if you guys have any ideas or input. thanks
   / radial arm saw plasma cutter #2
My first thought was, how awesome. Then I started to think about the advantages and could not think of too many. It's not hard to grab a straight edge and run your torch along it. It would be just another large piece of seldom used equipment in my shop. I really don't use my plasma much. A CNC table would be sweet, buty probably not used much either. Probably more for friends.
   / radial arm saw plasma cutter #3
Interesting... I do have an old Craftsman 10in radial arm saw and drawer stand sitting around taking space. Definitely a poor man's unit but for bunches of consistent straight cuts I suppose it could useful. Worse case it is a little used accessory to a cutting table. I will follow along. Good luck!
   / radial arm saw plasma cutter #5
This is my thinking exactly. BuckitCase Steve mentioned this earlier and I had it on my to do list.
The more I thought about it, the less enamored I was with the idea. (Sorry, Shiny Steve) Did a major shop clean up last week and well...this is where it now resides
image-695265188.jpg Terry
   / radial arm saw plasma cutter #6
Video Link: https://youtu.be/vxoFFD6_5xc
I love it. Seems really smart for a small guy. We don't have a plasma. Traded ours off years ago for truck work.
It could be made to take any tool from a plasma to a grinder welder. The sky is the limit
yeah i thought it was kinda like a extra hand, i see myself using to do repeatable angle cuts. i do custom furniture work and often need that kinda thing
   / radial arm saw plasma cutter #8
would replace the threaded rod and the battery operated drill. with a smooth rod. and then find some sort of handle to lock things down in place. perhaps 2 plates of metal. turned into a kinda of a vise or something to lock unit in position. and then when you want to make 90 degree cuts undo it. so you are completely in control of how fast you are cutting by hand.
that threaded rod / battery operated drill = good for ripping stuff down kinda like a table saw when you rip plywood and boards down. and allows you to lock things in place. but you are more needing just the "lock" and then a free form slide without a motor to move things back and forth.
might suggest pulling the grating out. and put some rollers down. for longer pieces of metal. and then when cutting shorter pieces of metal toss the grate back on top, and use a couple thumb screws /bolts to hold grating in place.
   / radial arm saw plasma cutter #9
Since radial arm saws have been replaced by power compound angle miter boxes, they are pretty much giving them away, so good use for a set of legs and a table. As you mentioned having to do lots of repetitive straight cuts, seems like a good use. Set up a jig to make the same cut over and over again.
How do you plan to make it trigger without you having to use your hand? A foot pedal might be nice. That would leave both hands free and not too awkward as it is now.
   / radial arm saw plasma cutter #10
Definitely a foot pedal is in Rednic's future.
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A50323)
2015 Chevrolet...
2011 Manac 36245B30 45FT T/A Walking Floor Trailer (A50323)
2011 Manac...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
