Any one use the garden "Pocket Hose" you see advertised?
   / Any one use the garden "Pocket Hose" you see advertised? #1
John White
Gold Member
Newark, Oh
Bob Cat Ct335
Any one have any experience with the pocket garden house you see advertised. My wife waters her flowers a lot and has over 100' of hose to drag. I wonder how the pocket hose would work.
   / Any one use the garden "Pocket Hose" you see advertised? #2
I had a couple at my past house and worked well, Moved to a new house and immediately blew out 2. My new house has 140PSI in the water line. Those expandable hoses will blow out if pressure is above 50PSI. The box stores and hardware stores sell a gauge that screws onto a hose nozzle for less than $10. My house has a pressure regulator but it still builds up to 140PSI if water not flowing. Possibly someone made a heaver duty one by now - check the specs on them for PSI. A lot of them do not give the PSI on their ads and only on the package.
   / Any one use the garden "Pocket Hose" you see advertised? #3
I've owned two of the 50' ones. Bought one for watering plants and flowers around the house. It worked well during the season, but developed several pinholes early the next spring. I got another one and it also worked well during the summer but the next spring it split down the length of almost the whole hose.
I figure they're good for one year and they're not too expensive, but I don't like replacing stuff so quickly. I've been using commercial garden hoses ever since.
   / Any one use the garden "Pocket Hose" you see advertised? #4
We sprung for one (pun intended). It's piled up next to the garbage can. I will say though - they sure have a commercial that make one want to jump up and buy a couple.
   / Any one use the garden "Pocket Hose" you see advertised? #5
I had a 50' one - laid out in the summer sun, under 50 lb pressure and ruptured like an over ripe banana. It "compressed" nicely and fit well in the garbage can. They may have heavier ones now - I'll just continue to use the HD commercial rubber hoses.
   / Any one use the garden "Pocket Hose" you see advertised? #6
Before I had county water I had a well with a 1 gpm refresh rate. When one of those hoses ruptures, it can empty a well like that pretty quickly.
   / Any one use the garden "Pocket Hose" you see advertised? #7
I must have a thousand feet of garden hose. My Mom bought me one of those pocket hoses. Like I need another hose! I keep it around in case I need a hose in the winter when all my hoses are blown out and put away.
   / Any one use the garden "Pocket Hose" you see advertised? #8
We had one. The dog liked how it recoiled after she pulled on it. Did not last long.
   / Any one use the garden "Pocket Hose" you see advertised? #9
They pretty much suck
   / Any one use the garden "Pocket Hose" you see advertised? #10
Wow! 140 psi? I thought my water pressure was high at 100 psi, and after I had the city water guy verify that my gauge is right, I just leave it there, but do have a couple of non-adjustable regulators that are primarily sold for RVs that I sometimes use to protect soaker hoses. And when we lived in a "manufacturer" home in the country and had over 100 psi, I put an adjustable regulator in the line to the house set at 50 psi.
But for garden hoses I now have 3 of the Gilmour Flexogen 8 ply 500 psi 5/8 diameter, kink resistant lifetime guaranteed hoses from Home Depot.
Stuccu: Best Deals on Gilmour Flexogen Hose Buy Exclusive Deals 70 OFF Save Big Lowest Price On Gilmour Flexogen Hose Best In Stock Fast Free Shipping. Up To 70% off!
They're thick and heavy but I have each of them on a hose reel, they stay outside in the weather year round, and after 3 years they still seem just like new.
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2025 K0608G UNUSED 3-Rail Style Fence (A53117)
2025 K0608G UNUSED...
2015 BMW 320i Sedan (A53117)
2015 BMW 320i...
Roller (A52377)
Roller (A52377)
Trojan 50CL 40mm Hydraulic Hammer, New  (A52384)
Trojan 50CL 40mm...
