Changing blades on a Kioti 72 in. finish mower
   / Changing blades on a Kioti 72 in. finish mower #1
JDL538
California Ky.
CK 30
I've tried every way I know and can't get the blade off.. Any one have one of these. I think it's a 2013 model bought it in June this year. Thanks for any help.
   / Changing blades on a Kioti 72 in. finish mower #2
Impact wrench.
Does anyone know if it's right or left thread?
   / Changing blades on a Kioti 72 in. finish mower #4
That will depend on which way the blades turn.
Does that mean it's the opposite of the way the blade turns ?
   / Changing blades on a Kioti 72 in. finish mower #6
I think it should loosen the opposite way the blade turns, but I'm not 100% sure.
   / Changing blades on a Kioti 72 in. finish mower #7
My 48" version of this mower has standard right hand threads and I use a battery powered impact wrench on it without issue.
Rancho
Rancho
Do You stop the blades from turning some how ? If I put a socket on the nut on the top it will just turn. If I stop the blades with a 2x4 it will just slip without the bolt giving..
   / Changing blades on a Kioti 72 in. finish mower #9
I had to grab the pulley neck with a pipe wrench to get mine off, miserable hot day job that I would have done differently in hindsight, like maybe using a bunch of penetrating oil first.
Mine were regulare righty tighty lefty loosy nuts
   / Changing blades on a Kioti 72 in. finish mower #10
My three blades are held on by NUTS (the type with nylon inserts), and I do hold the blade with my hand during this process, but it does not require any real pressure.
Rancho
2010 Ford Fusion Passenger Car (A51694)
2010 Ford Fusion...
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
John Deere 335 Round Baler (4ftx4ft) (A52748)
John Deere 335...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
1980 AM General M35A 2.5 Ton 6x6 Cargo Truck (A50323)
1980 AM General...
