Changing blades on a Kioti 72 in. finish mower
   / Changing blades on a Kioti 72 in. finish mower #1
JDL538
California Ky.
CK 30
I've tried every way I know and can't get the blade off.. Any one have one of these. I think it's a 2013 model bought it in June this year. Thanks for any help.
   / Changing blades on a Kioti 72 in. finish mower #2
Impact wrench.
Does anyone know if it's right or left thread?
   / Changing blades on a Kioti 72 in. finish mower #4
That will depend on which way the blades turn.
Does that mean it's the opposite of the way the blade turns ?
   / Changing blades on a Kioti 72 in. finish mower #6
I think it should loosen the opposite way the blade turns, but I'm not 100% sure.
   / Changing blades on a Kioti 72 in. finish mower #7
My 48" version of this mower has standard right hand threads and I use a battery powered impact wrench on it without issue.
Rancho
Rancho
Do You stop the blades from turning some how ? If I put a socket on the nut on the top it will just turn. If I stop the blades with a 2x4 it will just slip without the bolt giving..
   / Changing blades on a Kioti 72 in. finish mower #9
I had to grab the pulley neck with a pipe wrench to get mine off, miserable hot day job that I would have done differently in hindsight, like maybe using a bunch of penetrating oil first.
Mine were regulare righty tighty lefty loosy nuts
   / Changing blades on a Kioti 72 in. finish mower #10
My three blades are held on by NUTS (the type with nylon inserts), and I do hold the blade with my hand during this process, but it does not require any real pressure.
Rancho
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2012 Honda Accord Sedan (A50324)
2012 Honda Accord...
2013 Ford F-150 (A50120)
2013 Ford F-150...
CFG Industrial QK18R (A50121)
CFG Industrial...
