8n wont move?
   / 8n wont move? #1
kool cat
Marlbank,ont
Kubota 23s
long story short I was pushing a a little pile of dirt over with my loader and the tractor stopped, without warning. No gears (forward or backwards) but I have Hydraulics .
So my question is Are the Hydraulics hooked to the clutch?
I drained all the gear oil out nothing in it, didn't look too bad.
   / 8n wont move? #2
are the hyds hooked to the clutch?
everything is hooked to the clutch.
you have an input shaft after the clutch.. this feeds the tranny.
tranny has 2 outputs. the pinion gear for the rear end, and the pto coupler.
if you have hyds, then power is getting to the tranny, just not to the rear end.
most likely causes for no rear movement are:
sheared / stripped pinion to trans coupler hollow tube.
sheared rivits/bolts on the ring gear .
broke broke axle/sheared splines hub/axle
   / 8n wont move?
thanks for replying i will look at that.
thanks again
   / 8n wont move? #4
If it has a Sherman transmission, it could be in neutral. ??
   / 8n wont move? #5
last 4 words of the first sentence ont he first post:
he has hyds. main trans -**IS**- getting power.
sherman replaces the input shaft for the main trans.
if main trans IS getting power, sherman IS transmitting power, and thus NOT in neutral.
   / 8n wont move?
this is looking to the front of the tractor
   / 8n wont move?
what do you call that shaft its broke at the transmission?
will it slide through that bearing? or will i have to pull the transmission apart?
   / 8n wont move? #8
if you don't have a service and parts manual, email me and I will send you a pdf of the trans gear exploded diagram and part numbers.
   / 8n wont move?
I emailed thank you that for your help
   / 8n wont move? #10
those 2 pdf I sent should shed some light on the subject.
won't be fun however..
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2009 Yamaha YDRE Electric Cart (A50324)
2009 Yamaha YDRE...
71061 (A49346)
71061 (A49346)
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
