4bt cummins jeep tj
   / 4bt cummins jeep tj
Cost is not a big concern, it is more about the challenge and education.
it is aired up using shop air to tune ride height and check for leaks
Cutting action
4bt is going in
   / 4bt cummins jeep tj #194
The 4BT looks at home going into the jeep. Your boys look like they are enjoying it too.
Hood is closed but still new to build motor mounts
Started motor mounts but there are lots to do still
Very true😅
Motor mount take 2
Started the 4bt cummins motor mounts
   / 4bt cummins jeep tj #200
Are you going to use any triangular bracing on those? 4BT is around 800 dry, combine that with the forces of trail riding and you might see a failure.
I used 1/2" thick angle plus 1/2" bracing for mounting the 6BT into my Ford, it's supporting two turbos as well.
JOHN DEERE LOT IDENTIFIER 111 (A53084)
JOHN DEERE LOT...
2014 RAM 5500 Bucket Truck - 4X4 - Cummins Diesel - Automatic Transmission -Versalift SST40 Boom (A53472)
2014 RAM 5500...
2018 CATERPILLAR 299D2 SKID STEER (A51246)
2018 CATERPILLAR...
Set of Ag R4 Wheels and Tires (A53472)
Set of Ag R4...
2016 CATERPILLAR 325FL EXCAVATOR (A51246)
2016 CATERPILLAR...
