How much HP needed for a 72" belly mower?
   / How much HP needed for a 72" belly mower? #21
I have pulled a 72" finish mower with the little B7100, but anything higher than yard grass bogs it down. The B7100 is only 17 gross engine hp. My L3240 pulls the 72" finish mower with ease. It has enough power to smoke the belts off.
   / How much HP needed for a 72" belly mower? #22
Another thing, in a 3 point finish mower, I MUCH prefer a "rear discharge" over a side discharge mower! Along with some other advantages, the rear discharge needs a bit LESS hp to run it, because rear discharge mowers get rid of the grass faster...
SR
   / How much HP needed for a 72" belly mower? #23
SR
Second that on the rear discharge mower. It's the only way to fly. The grass is evenly distributed with no clumping and it's much easier to mow since you can go over the same place twice and not have to worry about rows of grass.
   / How much HP needed for a 72" belly mower? #24
Is the HP the same at the mid PTO and the rear PTO?
When ever power goes through gears some will be lost. Things like friction and force trying to push the gears apart rob power. The rear PTO suffer less power loss being in-line with the engine. The center PTO will normally have less because the power will to drop down. If you go to Kubota's website and look at a tractor that has a mid PTO you will notice that Kubota will not list attachments like front snow blowers for lower HP tractors equal in width to a rear option. For example my 4240 was the smallest that Kubota would list the 6' front blower for but the lower HP 3240 did have a rear 6' blower as an attachment.
   / How much HP needed for a 72" belly mower? #25
But on a mower you have to gear the rear pto up to similar speeds as the mid pto.
SR
I've heard that with a rear discharge you no longer have to sweep up the grass?
   / How much HP needed for a 72" belly mower? #27
I don't sweep up grass anyway. In regular yard grass there is not a big difference in side VS rear discharge, but in high grass it makes a huge difference.
   / How much HP needed for a 72" belly mower? #28
I use a ZTR or the bulk of my mowing, but use a rear discharge RFM on a 3-4 acre part of my property that is too wet and/or rough too use the Z on. I mow that every 10-15 days. The 60" mower behind my B2620 will handle 6-8" tall grass with no problem, and it looks good when I am done.
Will
   / How much HP needed for a 72" belly mower? #29
I used to mow at a 3" height with my B7800 and 6 ft side discharge mower and there was always clumping and annoying piles of grass. This year I switched back to my Woods 7 ft RD8400 three blade rear discharge mower and went to 3 1/2" high. There is zero grass to rake and mower is faster and a whole lot more pleasant. No more side discharge for me.
I mow mine at a 2 inch height and always end up with a mess of grass to rake up. I hate sweeping up grass! Have you ever tried it that low? My land used to be pasture for cows. I don't like mowing much in the heat of summer and it takes half my weekend up. That might change if i ever get a decent tractor one thing i don't like about a rear finish mower is it will take up a lot of extra space in the garage that a belly mower wouldn't.
Looks like you have a nice setup thanks for the pics! :)
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
404 (A52706)
404 (A52706)
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
