nauled on plywood shed / cabin / roof sheeting
   / nauled on plywood shed / cabin / roof sheeting #1
boggen
Elite Member
Trivoli, IL
SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
a 8x12 or so shed, on skids, bottom is off ground about 8" from that point to about 2 feet up. almost entire side has been nauled on like someone took a little drum sander for a dremal and eat up the side.
20 x 24 cabin with approx 6' x 24' front porch, cabin itself is fine, but on the porch there is a cabinet made from same type of plywood siding. were a critter has nauled at the bottom corners and side doors (edges of the plywood / doors)
then front porch the plywood roof sheeting was brought over it, and singles placed on top. right at the metal drip edge. something has nauled through some of drip edge, looks like it was chewed up by a reciprocating saw blade, were blade was not held steady. due to the jaggy-ness of the metal.
and then on the under side of the plywood sheeting up next to the drip edge. it looks like something has nauled all the way across in between the 2x4 rafters pieces. something like a little drum sander on a dremal. it is all fairly smooth. but in locations you can see were the plywood sheeting has little naul marks.
tearing off shingles to replace. and some dry root at the drip edge. extending about 1 foot from porch edge. does not extend into actual cabin. single layer of shingles approx 20 to 25 years old. assuming wind tore off the tabs in a spot on the front. and hence replacing shingles. if not tearing off shingles would of never noticed the dry rot.
the shed side also has some dry rot on it. were it was chewed / nauled up. the area shed sets in, is fairly damp / shaded pretty much all day if not all day long.
the shed, cabin set near lake. approx 40 to 60 feet or so up on top of a hill.
the more i type this out. is there some sort of creature / critter / bug that eats up dry rot wood? or goes after something in the dry rot? some sort of bird? beaver / musk rat? mice? squirrels? some sort of bug?
it is more eating the "surface" of the exterior plywood, vs making holes. and eating / nawing at the edges of the plywood.
Porcupine?
googling "porcupine damage" it looks like damage i am seeing. did not know central Illinois had porcupines!
skunks, possums, musk rats, coyotes, racoon, rabbits, squirrels, rabbits, deer. have seen. but porcupines? huh?
i see "bur's" like when you cut a piece of plastic pipe to a 2x4. and you have little splinters around the perimeter. but the overall nawing looks like images i am seeing of porcupines.
   / nauled on plywood shed / cabin / roof sheeting #4
Did you mean "gnawed on"?
Probably porky's.
Central Illinois is not mapped
from A Pointed Question— Just How Do Porcupines Mate? | Blog | eNature
as part of their range but maybe you've got porcupines that can't read a map and got lost :).
   / nauled on plywood shed / cabin / roof sheeting #7
   / nauled on plywood shed / cabin / roof sheeting #8
Would really help to see some pictures of the damage. My guess is it's squirrels. They are just mean that way and from what I've seen, chew on houses looking for a week spot to get into the attic so they can really mess things up. Raccoon's tend to focus on one spot and keep at it until they get through. Porcupines seem to like fresh bark more then anything else from what I've seen and I'm not aware of them going after buildings.
   / nauled on plywood shed / cabin / roof sheeting #9
Poking around I found something on the internet that said that Porcupines crave salt and certain building material treatments that seem like salt to them.
   / nauled on plywood shed / cabin / roof sheeting #10
Squirrels would be the most likely culprit, rabbits would be next.
UNUSED FUTURE 19" EXCAVATOR RAKE (A51248)
UNUSED FUTURE 19"...
2009 Chevrolet Traverse LS SUV (A51694)
2009 Chevrolet...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
JOHN DEERE 48" REAR BAGGER (A51248)
JOHN DEERE 48"...
UNUSED INDUSTRIAS AMERICA F12T HYD TILT LAND LEVEL (A51247)
UNUSED INDUSTRIAS...
2019 Altec DC1317 (A50123)
2019 Altec DC1317...
