Building our retirement home
   / Building our retirement home
The project inches forward. We've managed to get the plumbing set and the slab poured. Framer is on tap for sometime next week and it will be quite a relief to see something resembling a house take shape. The next step will have its own set of complications given that we made some size changes just before the slab sent down. The plans, in several places, no longer match the drawings. We'll have to meet, measure and make some adjustments before the hammers fly :)
   / Building our retirement home #163
I'm confident you will workout the details. Very nice big slab, by the way. Nice!
I may have mentioned earlier, we went into this with less than proper construction plans. Our designers were sending us to the poor house and we had to walk away. As a result, we were left with little more than floorplans - which have been modified several times by hand. Every step now raises questions ... Where exactly? What size exactly? How exactly? LOL
We keep pushing along and trusting all will end well :) We've driven hundreds of miles shopping for exterior stone and wood siding, kitchen and bath fixtures, doors, windows and counter-top granite.
In the pics, the slab nearest is the garage. The center spanned section is our basement, and the far slab consists of the Great Room and main living areas. Above the basement section will be the guest bed, laundry, mechanical room and pantry.
Ground floor living space should be around 2600 sq ft and the basement is approximately 1000 sq ft. Total "under roof" will come in around 5400 sq ft.
   / Building our retirement home #165
It's good to see the picture with the chairs under the rebar. But I'm at a total loss as to why there is no rebar in your footings? I've never seen this before and it's one of those things that gives me a lot of concern.
I believe the way to describe this would be a monolithic slab on top of a footing - sort of a hybrid from traditional stemwall & monolithic. The footing went in long ago, and the perimeter of the slab rests on that footing - which also provides the brick ledge. There are also a few concrete piers in the slab.
   / Building our retirement home #167
That must be the pad with the plastic. There are a few pieces of rebar coming up and at an angle. Those must be what's tying it all together.
   / Building our retirement home #168
We are also building our retirement home- rather the contractor is. We cleared the forest and built the driveway. Ours is 3300', brick, wired and plumbed for natural gas generator. Were supposed to take possession in a week or so but that is now delayed due to water damage from the floods in SC. Some roof, floor and sheet rock damage, not to mention some erosion. However, the very large dry bed I made (~180'x3.5'x3.5') to drain the sloping, now exposed cleared two acres worked wonderfully and directed the 21" of water runoff around the site the barn will be built. Although I did also lose some of the 350 tons of fill I had prepped for the barn's bed. Had another ~2" of rain yesterday. Oh well.
EDIT: I deleted this single pic of the house set off in the "Attached Thumbnails" box as it was an earlier photo and have no idea how it became posted.
We are also building our retirement home- ...
Very nice. Congratulations.
I can only hope we will eventually home something taller than the cement slab! tick tick tick Waiting over a week for the framing crew.
   / Building our retirement home #170
Looks VERY nice. Some nice details in the house. We start in the spring, Lord willing....
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A52128)
Morooka MST 660VD...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
Champion C80 B (A50322)
Champion C80 B...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2015 FREIGHTLINER...
2011 GMC Acadia SLE SUV (A50324)
2011 GMC Acadia...
2014 FORD F-350 SUPER DUTY CREW CAB FLATBED TRUCK (A51243)
2014 FORD F-350...
