Craftsman lawn tractor burning oil
   / Craftsman lawn tractor burning oil
I found a couple video guides for Inotek engines which are really good. I'll follow along and see what I find. Thanks!
I tested compression prior to pulling the head the other day and found that I was getting 90-95psi. The only thing I had done was pull the head cover, clean the oil, and reinstall. After rebuilding, I now have 120psi! I killed the battery by leaving the switch in the wrong position, so I couldn't start it up after getting everything back together, but this morning it fired up with pep and engaged the deck with a small puff of exhaust. Should run MUCH better now!
   / Craftsman lawn tractor burning oil #13
Good news.
The motor seems to run great after it warms up. Prior to the gasket failure (the large plume), I could turn the mower on and engage the deck immediately if desired. Now if I don't let it run for a couple minutes the motor will bog down and try to die. After it's been run for a few minutes, I haven't seen any issues.
I checked the spark plug and it has black on the sides but not the spark points. I haven't done anything to the carb, but I'm wondering if somehow it could have been bumped enough to require tuning? Black soot to me suggests it's running rich but I don't see any exhaust so I expected it to be a clean plug. Perhaps these engines have some small amount of soot even when running clean?
   / Craftsman lawn tractor burning oil #15
Wouldn't black soot indicate that it's burning oil ?
I was under the impression that rich gas engine didn't procude soot unless it burned oil as opposed to diesel.
I don't think it's not burning oil at this point. I ran it for a couple hours now and the oil is pristine and at the original level. I should pull the plug after it's run for a while to see if it looks the same or if the thin coating is burned off.
I didn't adjust the valve gaps as they seemed pretty close to the correct setting. The manual gave a gap tolerance and they were within that so I didn't bother trying to exactly center the gaps.
I can't think of any other tweaks that could be made other than tuning the carb. But, since it runs fine with no backfires/surges/choking/etc, I don't want to create a broblem for something of a minor issue (I think). The only other thing I can easily do (and should anyway) is change the fuel filter.
   / Craftsman lawn tractor burning oil #17
You might add some Sea Foam to the fuel to help clean it out. Expect some white smoke when you first use it.
I have a can ofseafoam but have never used it. Any recommendations on amount to use? Does it clean the carb or just the cylinder? I manually scrubbed the piston/cylinder surfaces prior to rebuild, so hopefully it works on the carb as well.
   / Craftsman lawn tractor burning oil #19
Sea Foam will clean the complete fuel system. From the tank to the cylinder. If I remember correctly one small bottle treats 20 gallons of fuel. Using more per gallon will not have any ill effect. I filled my 5 gallon storage tank and added 5 oz. Sea Foam to it and fill the mower from it till it was used up.
I just read their web site and the recommendation seems to be 2oz/gal is a good starting place. I replaced the bowl last year when the seal failed and it started leaking but I haven't done anything else with the fuel system. I'll try seafoam first anyway.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A53473)
JOHN DEERE ROW...
SHOP CART W/ FRONT & REAR HITCH'S (A51248)
SHOP CART W/ FRONT...
2007 FELLA SM350 3 PT DISC MOWER (A53473)
2007 FELLA SM350 3...
2013 KENWORTH T800 DAY CAB (A53426)
2013 KENWORTH T800...
